跳转到主内容
修复你的物品
维修的权力
商店
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3045 个问题 查看全部
iPhone 4s hardware in the body of a 4?
Here is my situation. I'm currently using my iPhone 4s. It is, for the most part, fairly functional but has a few issues & home button is missing. I was recently given an iPhone 4 that is in perfect cosmetic condition due to spending its entire existence in a life case , however it can not be updated any further & therefore many of my apps can not be installed on the it. My question is this, is it possible to switch all the inner hardwear of the 4s to the body of the 4? Looking at them from the outside they seem identical but I've never opened them up to see what's inside. I'm just curious if this is even something that can be done? Thanx
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Hi Brittney
The Long and short answer is no
Yes externally they look the same. But once you open them up you will see the Battery connection to the board is different, the screw arrangement for the main board is different . The "screen " flex cable pin config is the same but the way the "screen" is fixed to the body of the phone, that is different and we can go on . but we wont because I'm sure you have the idea now. Where we are, I would get on to FB and ask around for a broken down one and fix it up that way. And when you have one or two get on to the repair guides here and give it a go! best of luck
Regards
Charlie
这个答案有帮助吗?
得分 2
评论:
Thank you for the info. Not the answer I was hoping for but your response is much appreciated
完成的
添加一条评论
添加你的答案
Brittney Estrada 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 32
