跳转到主内容
加入维修社区 - 创建账户
由 Trio Tablets 制造的 Trio Stealth-10 MST 10-21 是 Trio 平板电脑系列中名副其实的“工作马”,它为用户带来了更大的显示屏和更快的处理速度。
Why is my trio stealth 10 screen display "@9 dual core"
When I turn on my trio stealth 10 my screen displays @9 Dual core. Can someone help me with this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Have you tried doing anything to it before you posted a question?
完成的
No because I can't get it off @9 Dual Core
完成的
添加一条评论
1个答案
You need to perform a factory data reset. I did this by going into recovery mode (Power button and volume down, release the power button after the logo appears, release the volume button after about 5 seconds). Choose wipe data/factory reset and then choose wipe cache (maybe optional) also. Please remember this will delete all data from the tablet, so if you don't have a backup, you will lose your data.
Choose reboot after this and it should boot up normally (takes longer than usual). This worked for me
这个答案有帮助吗?
得分 0
4条评论:
I have the same trouble with mine , i have tried to do the factory reset but it is now stuck on wiping data/formatting data in the rest. it wont actually reset . I have tried this multiple times ,i have wiped both the cache and media (they say wipe is complete on both) but the data wipe will not finish . is there anything that i can do ,I love this tablet and cant afford a new one . Any help would be AWESOME!! thanks
完成的
Unfortunately, if the wipe itself is not completing, it's probably hitting a bad part of your memory or something hardware related. Just my opinion though. Can you try removing your memory card if you have one in there, before trying a wipe next time?
完成的
I followed the directions and it went back to @9 dual core. What else can I do to get this @9 dual core off my screen?
完成的
I had to try this option 3 or 4 times. I was about to toss the tablet, thought I would try it one more time. Wah-la - it worked!
完成的
添加一条评论
添加你的答案
Sally 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 2,823
