跳转到主内容
加入维修社区 - 创建账户
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
Power and Lock Button Stuck, Requires Heavy Pressure
This is a first-run iPhone 4 that's in otherwise perfect condition.
Last night, the power and lock button became extremely difficult to push. I assume that there is some debris or that the button itself no longer presses (an issue I've noticed with Mid-2009/2010 MacBook trackpads as well).
I do not know whether or not there is a physical button that is being pressed, part IF182-004-1 shows a button with a level that I assume is actually pressing a real button.
I have removed the back of my iPhone, but I'd like some more information before I remove the logic board and void the warranty. The replacement guides don't have any information about this button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
16条评论
I had this happen to me last night. (Saturday) I have one of those otter box cases and the button still got stuck somehow. I believe apple has to replace it unless it's been dropped. I'm going today after work so I'll let you know.
完成的
they replaced mine twice. very easy about 20 min.
you have to make sure that you water indicators arent triggered though
完成的
I had an Otter box case on my iPhone 4 when the lock button jammed too! I have not been able to go to an Apple store yet...
完成的
does it cost any money to get it replaced
完成的
mine did this too but back glass is cracked and apparently i have water damage in the docking area, so they wanted to charge me $199 for a new phone :/ i hate apple.
完成的
显示更多的11条评论
添加一条评论
8个答案
最有帮助的答案
My lock button randomly stuck on my phone as well. I haven't "fixed" it, but there is a way around using it. If you go to general settings, an then accessibility, there is a feature called "assistive touch". Turn it on, and you can lock your screen from there. Hope this is helpful.
这个答案有帮助吗?
得分 4
1条评论:
What if the lock bottom still works but needs a big amount of pressure is there away to get it unjammed for say
完成的
添加一条评论
There are two problems with these button types;
The first is that they seem to attract moisture which can break the connection, this is why the home button on the iPhone 4 can slowly get less responsive over time. Check out this guide to help you diagnose any moisture damage inside the device. Also, to access the home button, check out this home button installation guide.
The second is that Apple chose to give the foil part of the button a little nipple like bit which raises it by less than a mm and this sometimes goes wondering around and this makes the external button sit that bit lower and not fully work. The fix for this is to put a tiny 1x1mm bit of 3M tape on the centre of the button and it should work. If this option doesn't release the button then the disk has probably gone flat and you will need a new home button.
这个答案有帮助吗?
得分 2
添加一条评论
Well,
You can always turn the phone on with the "home" botton and then program the Auto Lock to time out the phone after one minute on non use to power off
That is what is called "Problem solved" 'Merica way
Cheap, easy
Thanks
Scooter
这个答案有帮助吗?
得分 1
添加一条评论
go in to settings and then general settings then accessibility,scroll down to assistive touch and switch on ,you will have settings in your screen now
这个答案有帮助吗?
得分 1
4条评论:
thank you! I fotgot all abouy that..
完成的
I want to thank Terry and Lenny - I am an old lady that lives alone. My lock button was stuck so I could not use my phone. I love technology, although some days it does not want to talk to me at all. It would have taken me about 45 minutes to walk to office to call apple store to get help
I prayed and told God, He was going to have to fix my phone. Well while watching my Korean drama, and during the commercial, I found my self trying to find out how to change the battery, I found fix it.com.
I then hunted around the questions and lo behold I just went to the bottom of the page and both of your instructions were there and THEY WORKED. I will pray before I go to sleep I will ask Jesus to bless both of you.
THANK YOU SO MUCH!
embracecoach1958@gmail.com
完成的
Diane, it's Jesus here
I love technology too! And while I have no problem using my super-powers to fix cellphones etc, please try and remember that when your Korean drama is on TV, it's like 3am here in heaven! lol I heard you praying and woke up a bit confused!
Anyway, I went to bless Terry and Lenny (like you asked) and I accidentally clicked the "%#*@" button instead LMFAO It's soooo close to the "BLESS" button, Apple really needs to fix that in the next software update to the iCHRIST program! Sorry homeys, hope it's not too hot down there!
So don't feel bad, sometimes even the ol' J-Man is a bit "tech-illiterate" as they say! Take 'er easy, and if she's easy take 'er twice ;)
your pal
Jesus
完成的
And the 'Funniest Troll' award goes to......
Pure Brilliance!
完成的
添加一条评论
i have the solution ..... first open your iphone4, tail lamp cover removed ... uses a very fine tip screwdriver ubicated after the button below and above the power switch, position the screwdriver and gently press down a little ... Now blow with your mouth or a can of compressed air .... Test your button and go .. apparently it is dust that accumulates between the switch and the button
这个答案有帮助吗?
得分 0
添加一条评论
i had the same problem and I was to lazy to replace button so I put a pice of foil in between the button and the nipple and it seems to be working fine , you might need a pair of fine point tweezers
这个答案有帮助吗?
得分 0
添加一条评论
hi! what you need to do is take the phone apart, then take power button out and replace the proximity sensor, and clean around the power button, then when putting the new sensor ribbon in make sure the nipple is directly in the center of the plastic mount
这个答案有帮助吗?
得分 0
添加一条评论
this is a temporary fix but it has been working for me if u have on your ear pods a volume button and play and pause button. hold the pause in and voice control will pop up just use assistive touch to exit. Use the assistive touch touch button to lock it and use the home button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Monroe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 423,376
