跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
210 个问题 查看全部
Stuck on the update loop!#8002F1F9
The system update is stopped when it reaches 60% and it shows the error code#8002F1F9.
When I restarts the system, the system update starts from the beginning directly and repeats the same problem. What should I do? Please answer me fast...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 23
11条评论
I have this problem too, would replacing the hard drive solve it
完成的
I updated my ps3 and it showed me elan error code then i new what to de then it showed the same thing
=== Update (01/23/2020) ===
I am stuck at 49 and it dosent complet it and it appeared an error code 8002F1F9
完成的
HOW i reset muy PS3 from code 8002f1f9
完成的
When I restart it it keeps giving me a code thing
完成的
Replacing the CMOS battery fixed mine. Thanks for the advice!
完成的
显示更多的6条评论
添加一条评论
6个答案
已选择的解决方案
I had this problem. When I took apart the PS3 to clean the dust, replace the thermal paste and hard drive, I started getting this error when trying to update.
What fixed it was replacing the CMOS battery (watch battery on motherboard). From a suggestion from this guy. The CMOS battery change did the trick.
I am getting error code (8002F147) on my PS3
这个答案有帮助吗?
得分 9
5条评论:
How do you get the cover off to get to the mother board x
完成的
I have the same issue , stuck at 99%, then reboots. I have tried everything accept the wifi, bluetooth module., I formatted fat32 on both hdd and USB ran in safe mode, option 6, and ran untill 99%. I am going to investigate he wifi module though, what happened with my unit is I updated the unit and the power went off. Eversince I can't install the update. Any new help please??
完成的
You can try to replace the CMOS battery inside your PS3. This would involve you taking apart your PS3 though. So that depends on how confident you are with taking apart your PS3
完成的
Error code 8002F147 is caused by your console not being able to properly read the media that the update PUP file is on.
Source:
https://www.psdevwiki.com/ps3/Error_Code...
完成的
I actually got this error after a combined operation of dust cleaning, changing cooling paste and installing a new SSD plus a new cmos battery before trying to update. I got this loop and after reinstalling the original HDD it would not boot either.
After reopening the console
I found that the ribbon cable to the wireless module was not properly inserted during reassemby. After just reinserting that cable the update did finish and the ps3 worked as normal again.
So probably a bad wireless card in my case, but thankfully it didnt need to be replaced, just reconnected.
完成的
添加一条评论
Several possibilities:
1) Bad bluetooth/WiFi card - this is easy to replace.
2) Bad nor chip - this requires soldering
3) Bad Hard drive - this is easy to replace.
4) Try downloading the update to a USB stick and update that way.
这个答案有帮助吗?
得分 6
7条评论:
The real problem is with the bluetooth/WiFi card. It wasn't working before the system update. I'm afraid of removing the parts of ps3 and soldering. The SONY service centre said that, my ps3 can't be repaired and can only be replaced with a huge amount. What should I do now? Can I skip the update loop without completing it?
完成的
If the Bluetooth is bad, then no. The DualShock 3 uses Bluetooth to connect to the Ps3.
完成的
Yes, that's right. My controller is not working wirelessly. But please tell me a solution to skip this update. I cant play now. When I turn on the system, it will directly starts updating and repeats the same problem. I have no access to the XMB menu now... Please tell me a solution to skip this update without updating it.
完成的
Try this. While the PS3 is off, take out the hard drive. When you turn the hard drive back on, you will get "missing hard drive error code". Without turning off the PS3 again, simply insert the hard drive. According to another thread, the update may continue. Otherwise you will have to replace the bluetooth chip.
完成的
When I turned on my PS3 without hard drive, it shows a message like " hard drive is missing". No updates are going on that time. As you said, I inserted the hard drive without turning off the PS3, but nothing had happened. After sometime, I restarted my ps3 without removing the hard drive. Soon, the update started and stopped at 61%
完成的
显示更多的2条评论
添加一条评论
Had this error also. I let it restart on its own a few times but still get the error. So I held the power button down till beep (PS3 shuts off), unplug the power cord from socket for a few minutes (2-3 min should be good), plug it back in to socket, press the power button, update install should start up again. Mine completed after that!
这个答案有帮助吗?
得分 3
2条评论:
Was your ps3 connected to WiFi before you started the update?
完成的
Ayuddaaaaaa mi ps3 no quiere actalizar
完成的
添加一条评论
Error code 8002F1F9 means your bluetooth/wifi module isn’t working properly. That could mean the module, components on the module, or components connected to the bt/wifi module are faulty. Sometimes it can be fixed with a voltage regulator. I know this is an old thread but these are just suggestions/starting places for anyone that is still dealing with this. There’s no guarantee that any of this information will help you.
Source for error code:
Voltage regulator potential fix:
https://www.psx-place.com/threads/super-...
这个答案有帮助吗?
得分 2
2条评论:
I want to update my ps3 system but I saw this
Further notice.please remain on this firmware
And I have waited for an hour now I have seen nothing
What should I do please
完成的
Still relevant and helped me figuring out it was all caused by a loose ribbon cable (from motherboard to wireless module).
完成的
添加一条评论
Nesesito ayuda mi ps3 no quiere actualizar me dise de a producido un error 8002F1F9
这个答案有帮助吗?
得分 0
添加一条评论
I also have this problem. I tried to update my brother’s PS3 then it got stuck at 41% and showed the same error. I don’t know how to take apart and I can’t learn how to. Have a solution? Please I need to fix it.
这个答案有帮助吗?
得分 0
1条评论:
You can't learn how to?
完成的
添加一条评论
添加你的答案
Shinju Shaji 将永远感激不已
浏览统计数据:
过去 24 小时: 115
过去 7 天: 534
过去 30 天: 1,365
总计 96,389
