跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1623 个问题 查看全部
Broken iSight cable (pulled out of connector)
I pulled the wires out of the iSight camera cable at the logic board the connector is still in place I just pulled the cable out of the connector. How do I fix that?
MacBook Pro (mid-2012) 13"
Thank you
Update (03/09/2017)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Could you please send photo
完成的
Uploading a picture
完成的
添加一条评论
4个答案
已选择的解决方案
you need to replace the entire webcam with cable, which is difficult because you need to take of the entire display assembly and then separate the glass from the rest of the toplid.
这个答案有帮助吗?
得分 1
7条评论:
Ya I'm good on all that I don't need the camera that bad
完成的
You might want to use tweezers to push the broken connector out of the socket though. On some years it causes an issue with sensors, so the fan spins high speed
完成的
issues with fans are only when temp sensors are disconnected.
完成的
Fan is good I monitor it also with temperature of the CPU
完成的
On a good note it's only reaching 63 degrees C under heavy load.
完成的
显示更多的2条评论
添加一条评论
What are the effect of a broken isight camera cable on macbook 2012 pro …apart from camera….
I need answers thats based on sensor, relation of display back light
这个答案有帮助吗?
得分 1
2条评论:
i also wanna know.. because my computer suddenly cant find the wifi..
完成的
same situation here. Tore out the socket and was wondering if I really need to fix it.
完成的
添加一条评论
I have been using it without the connector for the past 1 year. All I notice for the difference is no more camera and mic is not working for me. I'm wondering if the mic has to do with the isight port or my mic just coincidence to breakdown at the same time. The rest like fan and sensors was not affected at all. I'm using a A1278 MBP.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Guys i have the same problem on macbook pro 13 late 2011 and I cant find a way to remove the connector. Any ideas please because thats must be the reason that my fan works like crazy. Appreciated any help!!
这个答案有帮助吗?
得分 0
1条评论:
That 's so hard to get it out. I using the cuter . Look at the side of socket. You found the space between the plug. So using the blade insert between that and Try to push the socket out. Please try the both side left and right. Until the socket going out.
完成的
添加一条评论
添加你的答案
Collin.nesbitt@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 40
总计 7,249
