跳转到主内容
The Nokia Lumia 710 is a Windows Phone smartphone with a 3.7" touchscreen.
10 个问题 查看全部
phone keeps displaying the nokia name going on and off on the screen.
the display makes it difficult to use the phone as it is not responsive. I could not charge it or have access when I call the phone from another set. Occasionally, I have access but just temporarily for me to view and it goes back into displaying the NOKIA on and off making the battery discharge. I am wondering if the battery is going bad at this time or what is wrong with the set?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Try connecting the charger with the phone off. Does it charge at all?
If so, allow it to fully charge and then try using the phone, without the charger connected.
If it starts to fail again shortly afterwards, switch the phone off and reconnect the charger, then switch the phone on and see if it now works OK, with the charger connected.
If it doesn't try the advice offered by @lpfaff1
If it does the most likely problem is that the battery is failing and needs to be replaced. How old is the phone? Even rechargeable batteries have a life span.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
@obbat , thaddeus obba , A factory reset may solve the issues you are having with NOKIA phone. Follow the instruction from the link below to factory reset your phone. Good luck.
https://support.t-mobile.com/docs/DOC-15...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thaddeus obba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 182
