跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
79 个问题 查看全部
Does anybody know how to disassamble Philips iron perfectcare GC9220?
The service manual says that you have to disassamble the TRAY MOLDED after removing the 2 screws under the TRAY RUBBER CAPS.
But I have 3 screws (only under 1 rubber cap has no screw) and I'm not able to disassamble or not even to move the try molded for a millimeter.
Who can help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@hschneider, Helge, Service manual link below on page 4 shows exploded view, which may help. Good luck.
https://www.manualslib.com/manual/953960...
这个答案有帮助吗?
得分 2
4条评论:
Thanks for your answer. But how you can read in my question, I have already read the service manual.
完成的
is it on page 7, shows 4 caps to remove, if all screws out use a screw driver to pry up at the front of cover to dislodge then slide foreword to remove. It may be possible that part 52 front bracket assy. may have to be removed if the tray/cover does not want to pry up and out. Good luck.
完成的
I have solved the problem.
Even after removing the screws you are not able to dissasamble the Tray Molded. Also you can't slide the tray molded forward.
You have to insert a screw driver carefully at the side of the Try Molded and lift it up. Then the same on the other side. Thanks for your help.
完成的
@hschneider, Helge, That is great you got it, thanks for posting back. Good luck with your iron.
完成的
添加一条评论
添加你的答案
Helge Schneider 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 2,896
