跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
Service Engine Soon.what this mean\
my car service engine soon came on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
The check engine light came on and the car is trembling
完成的
添加一条评论
3个答案
已选择的解决方案
Wayne Powell m , The SES light could be on because of an emission related fault. You can retrieve the codes with out going any where as your car is able to decipher why engine light is on by following the instructions in your manual or from the links below. 1st link can tell you what the code/s are also, after you have retrieved them.
ECM Diagnostics/ECM Reset procedure:
- Sit in the driver's seat.
- Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
- Fully depress and release the accelerator pedal five times in less than five seconds.
- Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the SES light flashes.
- Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
Use the link's below for more explanation if needed and if need be, some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button
http://www.brianhaddock.com/2010/reading...
https://www.youtube.com/watch?v=YlmGCS3U...
这个答案有帮助吗?
得分 10
1条评论:
Excellent instructions. This really helped me. Thank you very much for posting this!
完成的
添加一条评论
This is a general error given that the car detects something is wrong. Most auto parts stores (Autozone, Advanced Auto, O'Reilley's, etc) can plug a handheld computer into the car to check the specific error code that is causing the service engine soon light to come on. With that error code, they will be able to tell you what your car is detecting as wrong.
Additionally, you can buy the handheld computer and check the code yourself. Here are some on Amazon: https://www.amazon.com/Code-Readers-Scan....
You can even buy a connector that communicates with an app on your smart phone that can tell you the error code. For example: https://www.amazon.com/Bluetooth-Reader-...
这个答案有帮助吗?
得分 2
6条评论:
Most likely it means its time for an oil change. Normally this light comes on every 3500 miles.
完成的
Agreed. Though a lot of cars also have another indicator light for oil that comes on in addition to the "check engine"/"service engine" lights.
完成的
Engine service soon do not go off my Nissan Altima what it means what can I do
Answer please
完成的
What does it mean when u follow the instructions above to reset ecm and get the code and the "Srvc. Eng. Soon" light doesn't blink as it's suppose to. I have a 2002 Nissan Sentra. I followed the instructions 4 times and same result each time.
Thank you,
Tanya
完成的
HI since I did a multiple pedal ECU reset my xtrail 2002 crank but won't start it's now about 4 months code 1123 fuel pump works but no sparks injection looKS like no computer signal any know how to fix
完成的
显示更多的1条评论
添加一条评论
I Have a 2005 2.5 s Nissan Altima is there different 2.5s engine that come in the car
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wayne Powell m 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 72
过去 30 天: 303
总计 97,291
