跳转到主内容
Repair information for the Panasonic Viera GT24 Series 46 inch 3D plasma television. This television has model number TC-46PGT24.
4 个问题 查看全部
Power light comes on but no picture or sound
Was watching tv and screen went black sound stopped only sign of power is red light
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 30
29条评论
stephenbirdwell826 what exact model is your TV? Just to clarify, you have no sound and no picture? The only thing that works is the power LED and it is red?
完成的
my is no pic no sound no light
完成的
had the same problem! Great Pana tv and all of a sudden screen went black, no sound, nothing. the only thing i am able to do is unplug and replug and then the red light comes on and blinks then is solid. I can not turn it of with the remote or by the tv remote, i have to unplug manually.
How do i get to that engineers screen or whatever you guys are talking about. I cant afford a new tv either. or a repair man. I do follow directions really well though.
i tried the unplug, press power button process and nothing.
完成的
i have same problem with my panasonic tv the thing is the light isworking good not blinking but nothing works on the screen
完成的
i have the same problem with my element tv
完成的
显示更多的24条评论
添加一条评论
4个答案
已选择的解决方案
stephenbirdwell826 , First try unplugging TV for 20 min's and press and hold power button on TV for 10 sec's to reset and plug TV in and try. If no go remove the back from TV and remove plugs/ cables reseat them to make sure all have good connection and try TV again. At any time if you start getting light blink codes, use the 2nd link to diagnose the fault.
Could be possible power supply board issue, remove the back off of TV and look for any evidence of a power surge, bulged capacitor, hot/burn marks, etc., replace parts on the board or replace board found with defective parts. Check out the 1st link below for more info. on diagnosing a TV with this type of issue. If not comfortable working on the TV, have a good local TV repairman have a look, diagnose and estimate repair. Good luck.
https://www.youtube.com/watch?v=iHBIiRxh...
http://www.brainchamber.com/2016/03/23/p...
这个答案有帮助吗?
得分 14
6条评论:
I have a Philips 65PPFL6601/F7 TV that the power comes on, but no picture no sound. Already replaced the power supply board as it showed bad by Ohms. Any ideas?
完成的
My TV turns on you hear the sound then it switches off what do I do please tell me
完成的
Please tell me I need answers
完成的
Plasma tv blue screen for hours then big lines come on then turn it on and off and picture comes on why is this happening
完成的
My tv turns on with sound but no picture but makes a annoying sound when it’s on
完成的
显示更多的1条评论
添加一条评论
Basically all you want to do is go over to the TV power button that's on the TV and after turning it off using the button turn it back on but instead of releasing hold down that button after about thirty seconds the TV should turn back on again this is only if you're having the same problem as me which is where your TV has gone black but your power light is green and flickering or just staying solid otherwise I guess try the other methods that have been given to you but other people on this website
这个答案有帮助吗?
得分 8
4条评论:
If you're having trouble finding the on and off switch on the TV go to the bottom middle of the TV and it should be there if not try the edges of the said TV
完成的
It worked for about a minute then went off again
完成的
didnt work for me
完成的
Didn’t work for me. The last time it had done this I unplugged tv and the cable box. Waited 30mins then plugged them in. Tv then had came on. I did notice after pushing button if the screen turns blue around the outsides of screen it then comes on like it should.
完成的
添加一条评论
Try pressing the ‘i’ button on the remote’s number keypad . There is a ‘self check’ feature that activates if the blank screen and no sound is a settings problem. After that, press the tv/av button on the top of the set to get your tuner back on screen. Thereafter, to avoid having to repeat this every time you use the TV, just unplug it rather than turning it off by remote (- switching off by remote seems to trigger the problem that puts all picture and sound settings to zero one-by-one.)
这个答案有帮助吗?
得分 4
6条评论:
I don't have a remote I used my sky one with it but obviously as I have had to use another tv I registered my remote with that one :( I think it's a duff tv now, I reset it by the volume and on button, the green light disappears and nothing happens but must be doing somethi long with the light.going off! Just a shame to chuck tv away!
完成的
Yes it took a long time to find that trick.
完成的
I have a Panasonic tv the picture is black no sound or picture the power light is blinking could you help me find out whats wrong with the TV please and thank you model # TC-P50S30
完成的
I can’t find a tv/av button anywhere
完成的
I have a Panasonic tv and I have sound but only a black screen, can anyone help
完成的
显示更多的1条评论
添加一条评论
I solved mine. I had my old Panasonic Viera going black on me, no screen, no sounds. The power button was solid red after turning it on and not blinking like normal. We tried many things and already thought we had to go buy a new one. So, I grabbed the remote control and simply pushed the red ON button for a few seconds and the red light started blinking and the TV went on again. Solved! Hope it helps some of you. Cheers.
这个答案有帮助吗?
得分 2
1条评论:
I have a solution that may help! First I tried clicking the power button for a few seconds like some here suggested and when that didn't work, I clicked the "F" button on the TV + the volume up button at the same time, for a few seconds. Light turned green and TV is back to normal! Hope it helps!
完成的
添加一条评论
添加你的答案
stephenbirdwell826 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 77
过去 30 天: 422
总计 239,115
