跳转到主内容
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 个问题 查看全部
How do I get the on screen keyboard off of my touchscreen?
I have touch screen. My onscreen keyboard stays on screen all the time & I can not get directions how to remove it. It is a constant nuisance especially when I am typing anything. How do I get if off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If you go to settings and find your way to keyboard there should be an option to turn in on/off. If you Using windows 10 go down to cortana and type in "on screen keyboard" and there should be an option to turn it on and off. If your on windows 7 the easiest way is to do control+alt+delete and near the bottom left there should be an icon. Click it and there should be an option for on screen keyboard.
Hope this helps and good luck fixing!
这个答案有帮助吗?
得分 1
4条评论:
Wait Cameron or @cam2363..I thought I had it fixed but nope. the answers u provided were helpful but I did look to see that I have Windows 8.1 version. I tried control+alt+delete which did pull it up as u noted, but then after what do I note to take it off my screen. I will be eternally grateful if u can fix this. Thank u for your time.
完成的
When you dt ctrl alt del, look for this thing that looks like a 3/4 circle with 2 arrows. When you find it, there should be an option for on screen kb, just turn it off and that should fix it.
完成的
Thank u forever Cameron or @cam2363..I have been trying to get problem fixed forever, & now I have!! Thank u so much for taking time to answer for me, & then again as a follow up. Have a great day!!
完成的
No problem! Its just what i do! im super glad it worked!
完成的
添加一条评论
添加你的答案
Karen Bruce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 3,500
