跳转到主内容
The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
6 个问题 查看全部
Why the printer won't print
I tried printing but the paper just came out blank. Why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
完成的
Hi @ adnan abdul ajis,
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
完成的
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
完成的
hey my printer error, it can scan but its cant prin, and i can open the properties..
完成的
添加一条评论
1个答案
最有帮助的答案
No ink maybe? Lol does the rail for the ink cartridges move? Or does it simply spit the paper out
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Leolando Nable 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 3,227
