跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Replacement battery from iFixit
Hello!
I have this weird issue. I needed to replace 1) battery and 2) lighting dock connector on my iPhone 5.
When I took my phone apart 1st time i didn't realize I needed this f%#king tiny 5/32 flathead so I only replaced the battery and let it sit for about 2 days, I did NOT charge it or anything.
It started at 73% and looked like it was draining OK gradually to about 62% - I can't remember.
In about 2 days I got a flathead, opened my phone 2nd time, replaced lighting dock assembly. And after I turned it on my battery % started to read inaccurately.
I wanted to drain it down below 10%, so I started at about 42% or something and kept playing on the phone until the battery reached 9%. However, it got STUCK on 9%, I waited till the phone actually died (still showing 9% before), then I put it on charge and turned it on - it showed 1% (seems OK). I charged it for 9 hours straight. After 9 hours it would STILL SHOW 1% - so I hard reset my phone and it showed 100% - seems OK.
It was laying down for 6 days, still showing 100%. Now,
I turn it off / on = shows 31%
I hard reset = shows 62% immediately
I put it on charge, wait 1 hour, hard reset = shows 100% and stuck at 100%
I ordered this replacement battery from iFixit. Did I happen to get a bad battery or this is a logic board issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It is probably one of 2 things- a defective gas gauge in the battery or you broke off the filter for the gas gauge line next to the battery connector on the logic board. Check next to the battery connector for missing components or a scratched board.
这个答案有帮助吗?
得分 0
2条评论:
If its not the connector on the LB, can I ask for a replacement battery from iFixit?
完成的
Yes, you can contact them and ask for a replacement.
完成的
添加一条评论
Alright.
I have just put my OLD battery back in. It gradually charges and discharges literally on my eyes. Changes are reflected respectfully on the battery charge indicator.
I understand that this picture doesn't show sh%t, but those "filters for the gas gauge line next to the battery connector" are the microscopic silver cylinders right next to the connection and I guarantee that none of them look not any tiny bit damaged...
I'm calling it a battery and ask for a replacement. May the force be with me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haytham Alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 65
