跳转到主内容
华为2016年旗舰智能手机。拥有一体成型机身以及徕卡设计的双后置摄像头。拥有32/64 GB存储空间以及6种不同配色。包括型号有 EVA-L29, EVA-L19, 以及 EVA-L09.
72 个问题 查看全部
Backlight won't work after screen replacement
Good evening everyone,
I'm currently writing this because I haven't found anyone that has the same issue as I have. Briefly, I cracked my P9's display 2 months ago and since nobody fixes Huawei's products where I live, I decided to fix it myself by buying a new display on the internet.
At first, I didn't recognise that the display I recived wasn't the right one, the cable was black so it was supposed to be for the Lite version of P9 (great sellers...). As soon as I connected anything I turned it on but I could see pretty much nothing. Then I finally realized it was not compatible with my phone, then I ordered a new brand one once again, this time from another seller though. I was so happy that I could finally fix it and be sure it was going to be compatible (in fact it is compatible): same problem, I can hear every single sound, everything works but the display doesn't show up.
Now, I can see the screen with a lamp on it and the touch works perfectly, so surely the problem is the backlight that doesn't turn on at all.
Is it possible that I broke something on the mobo or the display that wasn't compatible messed up the display connector? I'm not trying to buy a new display because I'm mad at this and I won't waste a single penny on it furthermore.
Thank you in advance.
P.S. The displays are both Huawei original brand.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
i have same problem
完成的
添加一条评论
13个答案
已选择的解决方案
I'm surprised people are blowing up backlight circuits for Huawei P9 screen replacement. Did you guys forget to unplug the battery first?
这个答案有帮助吗?
得分 4
1条评论:
Actually I don't remember what I unplugged first, it could be that I unplugged the screen contact first, yes.
完成的
添加一条评论
Hi, have the same problem, I think the backlight diode is not working but I don't know when is it placed on the mobo and how to replace. There is many issue on iPhone 6 but nothing on any Huawei
这个答案有帮助吗?
得分 2
1条评论:
Hello do you know what the diode?
完成的
添加一条评论
Try this solution and say thanks to the good man
http://forum.gsmhosting.com/vbb/f846/hua...
这个答案有帮助吗?
得分 2
3条评论:
How do you short something?
完成的
Grand merci a vous les amis, ce poste m'a été d'un grand secoure.
完成的
Hello, i did everything like they said it in the forum, but the backlight still stays off. I'm not quite sure why, because everthing else works fine. Any ideas - Thank you.
完成的
添加一条评论
Has anyone already found a solution? I think I screwed up the backlight circuit indeed. I did see the post on the jumper for a p9 lite.. but haven't found a similar diagram for the p9.
这个答案有帮助吗?
得分 1
1条评论:
Same problem here, I can't find the similar diagram for mine P9.
完成的
添加一条评论
So I had the same issue, I was able to fix it by following something i found on a forum that was mentioned here. See this diagram
这个答案有帮助吗?
得分 1
2条评论:
Nice! Could you also post a link to the post where you found image? I need to know the second spot on the motherboard for the jumper. Or even better, how did you fix it?
完成的
I took it to a shop because I can't do the smd soldering myself. I think i paid €25.
I removed the motherboard and gave it to them so all they had to do was place the jumper. It worked so i'm happy.
完成的
添加一条评论
any solution?? I have the same problem, my screen broke and I changed it by a new one that worked for an hour, but after that the screen turned off but operating system is still turned on, I have tried 2 screens and nothing, what is the problem??
这个答案有帮助吗?
得分 0
添加一条评论
Also looking for a solution to this. Unplugged battery as always before changing screen. 2 screens no backlight. Anyone know where the backlight diode is?
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
I have probably the same problem. I have changed two LCDs the backlight I think isn't working correct because the lightning did not increase at all and some times the screen is flickering. I have changed and the battery but nothing. Any thoughts?
这个答案有帮助吗?
得分 0
添加一条评论
Hi
Try this solution
https://ibb.co/dBuiQ8
这个答案有帮助吗?
得分 0
1条评论:
This solution has already been givven 2 times on this thread. Why post it another time?
完成的
添加一条评论
I have the same problem the diagram given before is different than for Huawei P9 EVA-L09
这个答案有帮助吗?
得分 0
1条评论:
does anyone have a diagram for a huawei x1? i blew the backlight and cant find any info what needs to be jumpered
完成的
添加一条评论
The solution here aren't for p9, I'm still finding it difficult to rectify this problem.
这个答案有帮助吗?
得分 0
2条评论:
I still find it difficult to rectify this problem
完成的
They are for the P9, why would you say they are not?
完成的
添加一条评论
Huwaei P9 Lite 2017 Pra-Lx1 backlight solution?
这个答案有帮助吗?
得分 0
添加一条评论
for p8 lite 2017? solution?
thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Valentino Poltera 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 30
总计 16,842
