跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone5 stuck when I install front camera and sensor cables to board.
Hello,
I broke my screen and I replaced the screen and digitizer 1 year ago. I replaced it. It worked fine until last week. My phone's battery was swollen. So I bought a battery and install, it was simple.
When I tried to power up, it stuck at Apple logo. I worried and try to restore from iTunes. It gave error 4005, 4013, 4014... I searched and found some videos, explain the reason may be some defective components.
I started to disconnect connectors one by one, and bingo, it was front facing camera + ear speaker + prox sensor.
When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.
Before replacing the battery, everthing works fine. I switched to old battery but didn't solve for camera and ear speaker problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Replace the front camera ribbon cable assembly. It has gone bad.
Guide to replace:
iPhone 5前摄像头及排线替换
Where to get part:
iPhone 5 Front Camera and Sensor Cable
iPhone 5 Front Camera and Sensor Cable图片
产品
这个答案有帮助吗?
得分 4
3条评论:
Will it be the definitive solution? Is it a guess or fact?
完成的
I can't answer that unless i have the device in front of me.
完成的
'When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.'
What else would it be really?
完成的
添加一条评论
Yes you have to replace the front camera ribbon cable assembly, then only it will work bcoz once i replace the display by mistakely the front camera cable was got damaged and i start connect all the connectors the device was stuck and i replace the front camera cable assembly it worked for me, So pls try it
这个答案有帮助吗?
得分 1
添加一条评论
I bought a new camera ribbon cable assembly.
I will try tonight and let you know the result soon.
Thanks.
这个答案有帮助吗?
得分 0
2条评论:
It worked. I replaced the full front camera ribbon cable and works fine.
完成的
Great you did it nicely
完成的
添加一条评论
添加你的答案
Cagdas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 70
