跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
358 个问题 查看全部
xbox one storage/hard drive enquiry
Hi! New to xbox soon. Do you need a laptop/pc when changing storage/ hard drive on xbox one like you do with ps4?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Justin G, thanks for taking the time to answer my query. Also, for all the information you gave. Much appreciated!
完成的
It's what I love to do! Is it the Xbox one S or just the one? Feel free to contact me when you get Xbox live and maybe we can join up on there!
完成的
Are you talking about internal or external? If it's an internal your talking about the below answer doesn't work.
完成的
Justin G. Xbox one s - FIFA 17 1T
完成的
添加一条评论
1个答案
已选择的解决方案
No, the xbox will format the hard drive itself.
Scroll left from Home to open the guide.
Select Settings.
Select All settings.
Select System.
Select Storage.
Select Manage storage. If you see your storage device listed, your console has detected it.
If your Xbox doesn't recognize this right away..
Select Settings.
Select System.
Look under Console info & updates. If it says Update available, there’s an update you need to install.
After you’re done installing the update, go back to Settings and select System, and then Storage. See if your device appears in the list.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
john paul 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 97
