跳转到主内容
加入维修社区 - 创建账户
2.3GHz、2.6GHz 或 2.7GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.7GHz),配备 6MB 共享三级缓存。
Difference between Mid 2012 fan and newer fans?
Hi! I've been having issues for a while now with the right fan on my mid 2012 Retina 15" MacBook Pro. It makes a constant rattle and I've finally decided to fix it. The problem is the fan for this specific model is out of stock/very expensive in most places because it's slightly outdated. I see that the fan for the newer model is more widely available so I'm wondering if I can use this fan instead? From what pictures I've seen, the mounting holes appear to be identical and the power connector is similar as well. Is there some incompatibility that I'm unaware of (ie voltage, airflow etc)?
Thanks!
Items in question:
Mid-2012 MacBook Pro 15" Retina (Mid 2012-Early 2013) Right Fan
Newer MacBook Pro 15" Retina (Late 2013-Mid 2015) Right Fan
Replace a right fan compatible with MacBook Pro 15" Retina (Mid 2012-Early 2013) A1398 laptops. Part #923-0091.图片
产品
$44.99
Replace a right fan compatible with MacBook Pro 15" Retina (Late 2013 - Mid 2015) A1398. Part #923-0668.图片
产品
$39.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Should be compatible. From working on these before, there is no noticeable difference between the 2012-2015 fans. They use the same connector and have the same screw hole locations.
这个答案有帮助吗?
得分 2
1条评论:
Just tried it. Didn’t work. In fact the Mac won’t boot with that different fan. Bought a 2012 fan off eBay now. Was hoping the late 2013-2014 with the longer fan blades would work on it. If you actually try it, the screw placement is a bit off, whereas the right fan on the right MacBook just fits.
由完成的
添加一条评论
No. Get the 2012 Retina fan from eBay. Just bought one for $5 after some price offers/negotiating. You should be able to get one under $10.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 415
