跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
293 个问题 查看全部
Issue with video after installing new hard drive
Hello! I've searched for this problem in past posts but I didn't see it, I hope it hasn't been mentioned already! Today, with the help of a friend, I replaced my failing seagate 500GB hard drive with a 2TB barracuda seagate hard drive. I followed the tutorial on this website to a tee. (I even wore rubber gloves to avoid finger prints lol.) Anyway, after I installed the drive and put the computer back together, and started to install mac OS, there was green gittery pixels all over the screen. At first I thought I had some how damaged the LCD but then when OS was done installing and going through the intro sequance movie, I see that alot of the screen was coming up green and the gittery pixels were moving all around. I'm assuming (and hoping) this is a video issue caused by an improperly seated cable from the LCD screen. I wasn't sure I had it all the way in as it was hard to see with the poor lighting I was using. Has anyone encountered this issue before? If so, what was the problem/soloution? Should I just take it apart again and re seat the cables? Please educate me!!! :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Ok, so I took it apart again, unplugged and re plugged everything. Now it's different. I have red pixel issues during the white screen loading (before nothing odd happened during white screen), HOWEVER alot of the pixel noise is gone once it's logged into OSX. There was a horizontal and vertical line that are both no longer there and most of the gittery pixels are gone, however, some still remain and in the same areas as before. I guess I'll do it again lol
完成的
So I installed Windows 7 on my iMac and all the visual issues have stopped. Even the red pixels on the white screen, everything looks perfect. Odd.
完成的
添加一条评论
1个答案
最有帮助的答案
If it was working before you replaced the drive I would certainly go back over everything I touched and make sure its correct. Give that cable special attention. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Curtis Day 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,317
