in my acer after installing windows 10 my touchpad is not working?
my acer aspire E 15 es1-512-c3x9 after installing windows 10 enterprise the touch stop working, and i don't even see the driver of my touch pad even after installing them, and when i try to change the the bios setting from legacy to uefi it say not bot file then i change to legacy and it boot yet touch pad not working how to fix please help .
thanks .
23条评论
Hi,
Have you checked if the touchpad is listed under either Mice and Other Pointing Devices or just Other Devices in Device Manager? See if there is a listing for a USB touchpad controller.
由 jayeff 完成的
Hi, Acer machines often have a key that turns off the touchpad. It is often a function key (Fn) and is often on the F7 key but could be anywhere. The symbol looks like a hand on a square with a small circle and diagonal. Make sure your touchpad is not turned off. The key is pressed once (along with the Fn key) to turn on and again to turn off.
由 Paul Ingarfield 完成的
I tried many times to use (fn) with f7 but still not working don't know whether I'm doing it wrong What must I do help me plz.
由 Zizipho Madikazi 完成的
I use the pointer to access driver manager so it it's not functioning I cannot do that. No pointer= no browser, no file explorer, no nothing. It highlights but no action. And no hand on a square w/small circle and diagonal (is it the F8?) And how would I know if the touchpad is on or off? It's an ELAN pointer
由 Barbara Danfordhirsch 完成的
Hi @ Barbara Dandfordhirsch,
Connect a USB mouse to the laptop and use it to navigate through to Device Manager etc etc
由 jayeff 完成的
显示更多的18条评论
