跳转到主内容
问题已关闭
DC in board testing?
Hi All!
I'm wondering if there's anyway i can test the DC in board to ensure its functioning properly?
I had a liquid spill and since then the light on the ac adaptor is dim and the OS reports "Not charging" - BUT, when left plugged in it does seem to trickle charge.
Edit:
I do get power to the board as it trickle charges. Runs fine from battery. The info i'm looking for is basically what lead on the board can i test for resistance and connectivety to ensure enough paower is pased to the logic board. Unit will NOT run without the battery...I'm assuming there isn't enough power to support the logic board on it's own.
Any direction would be appreciated.
Cheers!
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Deleted my answer because links no longer worked
Please more infos about the MBP current state. Do you get power to the main board ? Does the machine work when powered only by the battery ? Etc...
anyone have any advice?
添加一条评论
2个回答
Here is a thread about someone with a similar problem. Good luck.
http://boardreader.com/thread/Macbook_13...
这个答案有帮助吗?
按维修分数 0
评论:
thanks, but looking for more detail
添加一条评论
I have the same question. Does anyone know the voltage readouts for the DC In board connector that leads to the motherboard? I want to verify that the board is putting out enough voltage and would rather not replace it if the problem is with the motherboard.
这个答案有帮助吗?
按维修分数 0
评论:
Depending on which magsafe you have it is going to be 16.5v to 18.5v coming in. The other major measurements on either board are going to be 3.3v. 5v & 12 v - the same on any on other computer board, those are your measurements on the major rails..... Apple, Dell, HP..... it doesn't matter.
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,768
