跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Vibration doesn't work when the phone is completely assembled.
Hi everybody. I recently changed the LCD screen of my iPhone 5s (third party, works perfectly). When I reassembled the phone, I realized that the vibration was not working. I opened the device again, and realized that the vibration works perfectly as long as the LCD is not completely inserted. As soon as I press the LCD to make it fit into the back case, the vibration stops working. I think it is some kind of contact's fault. Any suggestions? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You probably have some contact or friction between the screen assembly, specifically the camera and sensor housing, and the vibrator. It could be physically obstructing it or causing a bad electrical contact.
Go back though this guide to double check that you have everything properly installed.
这个答案有帮助吗?
得分 3
2条评论:
Fixed! It was indeed a mechanical issue, a little part of metal of the front camera housing was pushing on the vibrator. Thanks a lot!
完成的
My pleasure!
完成的
添加一条评论
Hi
This is cause of display thickness plz try with another display or check something near vibrator might struck
Hope It Works
Thanks
Varun
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ignitus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 71
