跳转到主内容
A bridge, DSLR, point-and-shoot camera released in January 2013 sporting a 16 megapixel image resolution, adjustable aperture, and 30x zoom. It also weighs just under one pound, which is great for the traveling photographer.
4 个问题 查看全部
问题已关闭
removing front glass lens
in the earlier series the first lens by the cap could be removed like a normal lens by unscrewing the holding ring is this still possible with the s4850 model? would i need a rubber cup to do this???
Update (02/16/2017)
well actually the curved lens is what i remove to clean it. but it usually has 2 indents to put a lens wrench to it , But i have noticed they use flat rings and rubber cups.
Thanks for the replies
bryan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you talking about a cover glass (filter) which is screwed into the front lens threads? Can you take a picture so we can see what you are talking about here.
Some cameras don't offer a threaded mount but instead offer a bayonet or just a slip over lip for a hood attachment.
The curved lens its self is not something you should remove as the alignment of the lens group is dependent on it's mounting.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 207
