Hi, here's how to update the firmware.
1) Firmware is at this page along with manual to upgrade.
http://www.jvc.net/cs/car/firmware/2014/...
2) Download the firmware (ends in .rom) at the bottom of the page.
3) Copy the Firmware to a thumb drive.
4) Connect Thumb drive to the radio
5) Press and hold MENU
6) Turn VOL knob and select SETTINGS, then press the VOL knob
7) Turn VOL knob and select F/W Update, then press the VOL knob
8) Turn VOL knob and select SYSTEM, then press the VOL knob
9) Press the VOL knob again
10) Turn VOL knob and select YES, then press the VOL knob
The firmware should update at this point.
11) After about 5 minutes the update should complete. Press the Detach to button Release the faceplate
12) Press the RESET button for the update to take affect. and put the faceplate back on.
1条评论
Hi @deniscon
You say that it doesn't work anymore.
What phone(s) did it work with before, the same iPhone 6s you mentioned? Also what exactly is not happening? Can you pair OK etc?
A bit more detail as to the problem and also any relevant details e.g. phone upgrade or update, car power problem perhaps, might get some more helpful answers, if the firmware update didn't solve it.
由 jayeff 完成的
