Can it be hooked to a hard drive
I want to hook a external hard drive to the next book will it let me do this
James --
There are a couple of issues here: connectivity & power.
The Nextbook needs to provide enough power for whatever device you connect. Simplest test for this is to use a USB flash drive since they require little power. For a larger device, be sure the Nextbook is plugged in charging mode to provide the most power.
Next: What is the Operating System of your Nextbook?
Good luck,
Russ
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,639
2条评论
Best way to find out is to just try it. Connect a USB drive, power up and see if it recognizes it.
由 Russ Walden 完成的
Has anyone replaced the internal 32GB with more storage,or is it hardwired?
由 Igor Schmidlapp 完成的
