跳转到主内容
修复你的物品
维修的权力
商店
Replace the front glass ONLY and not all the LCD/digitizer
How can I replace only the front glass and not the whole lcd/digitizer?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个回答
最有帮助的答案
Here is a video tutorial.
https://www.youtube.com/watch?v=rMG57NVH...
这个答案有帮助吗?
得分 2
评论:
Hello S W, thank you for your answer and sorry for my late response.
I saw that video before but the problem is that from what i see at 4:05 of the video, normally the front glass is glued to the lcd/digitizer part. is it easy enough to unglue the front glass from the front glass without damaging the lcd/digitizer unit?
完成的
添加一条评论
unless you have the right equipment don't even try this, just replace the entire assembly.
这个答案有帮助吗?
得分 1
评论:
What would the right equipment be?
完成的
添加一条评论
添加你的答案
Lazaros Papadopoulos 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 934
