跳转到主内容
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103 个问题 查看全部
I'm having issues with the jbl connect feature.
When I connect my JBL Xtreme to my Charge 3, the audio cuts in and out between either speaker. Is this a common issue or is one of the speakers possibly defective?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
did you tried new charger and cable ?
完成的
No. I have the original chargers for both speakers and they work.
完成的
Having the same issue with two Charge 4 speakers. I've been talking in circles with “Harman Lifestyle Division” for OVER A YEAR and getting nowhere!
It happens when you press the Connect + (Party Mode) button and it will immediately start having some distortions and then after a little while it will start to crackle and pop. You don't even need two speakers necessarily, only to press the Connect + (Party Mode) button.
You can easily observe this when you play a single sine wave tone (from a free online tone generator.) If you play a tone below the high pass filter of the speaker (40Hz for example) and press the Connect + button you will immediately hear distortion. If you press it again 99% of the distortion will be gone but of course - now you can't use “party mode” since it's off.
I believe the only way to address this is through a firmware update.. or it might be impossible and Party Mode might just be a very poor quality feature.
Either way, WE DESERVE TO KNOW! Please send Harman Support e-mails if you purchased two speakers and tell them you have a problem. Please be polite but persistent. Maybe if enough people do it they will finally address this and if not, maybe a class action lawsuit might be the solution.
完成的
添加一条评论
5个答案
最有帮助的答案
I have the same issue, when I use connect +, it crackles and cuts out. Even when they are 1 foot apart. I reset both speakers.
这个答案有帮助吗?
得分 2
2条评论:
Oh that might actually be the issue. Thank you.
完成的
Reset JBL Charge 3 by holding Play/Pause button & Volume Up (+). Once switched on, no more issues.
完成的
添加一条评论
Delete all speakers from Bluetooth and keep only one .
这个答案有帮助吗?
得分 1
1条评论:
^^This is it!
完成的
添加一条评论
1st: Remove all stuffs from bluetooth devices.
2nd: add only one speaker. (Do not add others speakers)
3rd: Connect the device previous added, and play music… after that, click on de speaker button (connect +) and repeat this (click to Connect + button - top of speaker) on others speakers.
这个答案有帮助吗?
得分 0
添加一条评论
So I finally found the reason for the crackling and cutting out in my situation. It was disturbances from other devices near by that are paired with (and trying to connect to) my phone that I was playing music from. Solution:
  1. Identify bluetooth devices (other speakers, headphones etc) in your home that are paired with the device you are playing music from and turn them off.
  2. Hard reset the jbl speakers your are trying to connect together.
  3. Connect one of the jbl speakers to your music source (phone, etc).
  4. Start playing music.
  5. Connect the jbl speakers using the connect feature.
这个答案有帮助吗?
得分 0
添加一条评论
Ok I have got 2 boombox for a wile now and never have a issue so from one day to another it start giving me this problem I could figure out what could have changed so one thing i noticed that i have both speakers conected to Bluetooth on my phone even if i turn off the Bluetooth on one problem continue but when i forget one of the speakers on my phone the problem disappeared immediately this fixed my problem now I can listen music of the Bluetooth whit out auxiliar giev it a try
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arichie22 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 28
过去 30 天: 114
总计 14,206
