跳转到主内容
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 个问题 查看全部
PSP won't turn on or charge after being left in below freezing temp
I ordered a PSP 3000 on eBay, and the seller shipped the device with the battery in it. The PSP was in my mailbox for 3 or 4 hours in roughly 15-20 degree Fahrenheit weather, and the battery became swollen and no longer charges. The PSP would not power up when plugged into an AC adapter. I took it apart and found that the power fuse (I believe it is labeled "TD") was blown. I bridged the fuse with some tin foil and plugged it into the AC adapter. The green power light came on, but would not turn off even if I flipped the power switch. After some wiggling of the tin foil, I saw a few small white sparks and the green power light went out. I tried dropping a dab of solder on the fuse but it still wouldn't turn on again. How can I get this device up and running again? Also, where are all of the fuses located on the ta-095 circuit board? Thanks guys
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You should replace the battery
这个答案有帮助吗?
得分 0
1条评论:
There were fuses blown in the device. Would a new battery allow it to turn on?
完成的
添加一条评论
添加你的答案
Dino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 292
