跳转到主内容
修复你的物品
维修的权力
配件 & 工具
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4019 个问题 查看全部
Keep getting Error 4013?!
The phone has had its screen replaced. It has also been water damaged. But! It has been repaired twice and has been working fine for weeks and now it suddenly powered off and is now stuck at the itunes restore screen. Tried restoring with multiple different cables on two different computers and it just keep coming up with error 4013. Help?!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
已选择的解决方案
Error 4013 is usually NAND related but can also be caused by a whole bunch of reasons. Considering your phone was previously water damaged, the error is probably a latent issue that just now appeared.
Was the phone ever properly decontaminated (ultrasonic bath etc) or was it just dried...and heaven forbid, left in rice?
Other than a good visual inspection (you may find some obvious issues) or changing the battery as Ben suggests, I think you should look for a pro that does water damage and micro-soldering repair.
这个答案有帮助吗?
得分 3
评论:
Haha not rice, but 99% isopropyl alcohol bath yes, no ultrasonic. I own a cellphone store and have years of experience but nothing is fixing it this time! Guess it may be a microsoldering job :/
完成的
No offense intended about the rice, I didn't notice your were a tech. Yeah, probably a logic board issue. Do you have the tools? You can check out my profile or that of several other regular micro-soldering contributors here.
完成的
Oh none taken! :) But okay thanks!
完成的
添加一条评论
最有帮助的答案
Try another battery. It seems the 4013-4015 iTunes restore errors have been fixed a lot by replacing the battery with another one.
这个答案有帮助吗?
得分 3
评论:
wasnt the battery this time, but thank you
完成的
添加一条评论
添加你的答案
Austin Harris 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 8
总计 580
