跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What Causes Wifi to Grey Out?
I am here to ask what are all possible causes for the wifi to become greyed out on an iphone 6?
... I sold a phone with wifi working, and theyre now complaining its greyed out. Could it be from them leaving it in the sun on the 45 min drive home?
thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
WiFi Chip IC 339S0228 (Yes this has Bluetooth and wifi together in the chip) needs to be either reballed or replaced.
You will need to search for someone that replaces the wifi IC chip.
Look for someone that offers board level microsoldering on iPhones and they should be able to replace or fix it.
这个答案有帮助吗?
得分 3
3条评论:
@benjamen50 do you do that type of work in Australia?
完成的
No I personally don't but I do have a friend that does microsoldering (charging IC, touch ic, power management ic and etc). I just either refer people to them or take it down and hand it over to my friend to do.
完成的
maybe the OP @zaceustace could click on your icon and email you to get the location in Aussyland of where to get it fixed.
完成的
添加一条评论
最有帮助的答案
Go see Ben @benjamen50 here:
http://mtwo.com.au
这个答案有帮助吗?
得分 4
添加一条评论
No, maybe they dropped it and wifi chip came lose. Is Bluetooth still working?
这个答案有帮助吗?
得分 1
12条评论:
yes blue tooth is still working - edit: bluetooth not working
完成的
Im looking for proper answers... not people looking to $@$* post for rep.
完成的
That is wrong, it can be caused by leaving it in the car. The heat could have made a cold solder joint, try to reflow the chip and if that doesn't work try a new IC.
完成的
Thank you for proving that is possible (ver heat in car) ... so can I safely say the problem was caused by the user/conditions and not my fault?
完成的
Oh and btw I am in Australia, and it was hot that day.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
ZsTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,822
