Why does the sniper rifle have such poor range and power?
Just received a longstrike cs6 and it looks great but has very poor firing range, destroys bullets, and has extremely poor power. Any ideas for repairs?
@joshmatt, Joshua , There is an internal rubber O-ring that could be damaged allowing air to escape in the chamber or O-ring may need a little lubricant on it. By repairing it you may see improvements in the firing range. Will post a link below to show how to access the O-ring for replacement. Good luck.
这个答案有帮助吗?
I'd also look down the barrel and see how smooth it is and if the is any plastic flashing that needs to be trimmed down. This may be tearing your projectiles up.
mayer, thank you for the input, very good recommendation, Joshua as mayer suggest look in the empty barrel for plastic flashing, if there is flashing present try to scrape majority off with a thin sharp edge, then roll up a part sheet of fine sandpaper onto a pencil and use to smooth the flashing right down.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 148
