跳转到主内容
修复你的物品
维修的权力
商店
Repair guides and support for LED, LCD, HD and other Vizio TVs.
741 个问题 查看全部
Another VIZIO turns off randomly
I have a VIZIO 42" LED TV, model E422AR, about 3 yrs old (out of warranty). The TV is wall mounted in my bedroom. A few months ago it started randomly 'turning itself off'. By random I mean it might not happen for a few days, then happen several times in the course of a minute. The usual pattern is it happens a few times each evening.
When it happens, there is no picture or sound, the same as if I had manually turned off the TV via the remote, but with one exception: the VIZIO logo on the bezel beneath the screen remains lit, and is 'brighter' than it is normally when the TV is on. Other than the brightly lit logo, the TV appears to be in its normal off/standby state. In fact, if I then press the power button on the remote, the TV turns back on and all is well again (picture and sound) until the next time it decides to randomly turn itself off again.
After doing some hunting around online, I found many other VIZIO customers complaining of similar symptoms, although in most of those cases I the TV either failed completely (wouldn't turn back on), or the user had to unplug the TV, wait 10 or 15 secs, then plug it back in to get the TV working again (I've never had to do that). And no one described their TV's logo as still being lit when the TV failed.
Since most of the failed cases I read about turned out to be a bad power supply board, I went ahead and purchased one online. It was an exact match to mine, right down to the board's manufacturer, part number and rev letter. I went ahead and swapped the boards, powered the TV back on, and within a couple of minutes it failed again with exactly the same symptoms. %#*@.
So at this point I can safely assume that either the problem is *not* the power supply board, or the replacement power supply board I bought online has exactly the same problem as mine (certainly a possibility; I'm sure the board I purchased was used).
I have a hunch that the TV's hardware is ok, that this is some sort of glitch in the firmware. I can imagine there are points in the code where the default action in response to some error condition is to put the TV into the exact same state I'm seeing now. I could test out that theory by reverting back to an earlier firmware level and see if the problem disappears or the symptoms change, but it appears VIZIO offers no way to do that -- not only is there nothing in the TV's menus for loading firmware, but there are no firmware downloads offered on VIZIO's own support site.
I have no service manual or schematics for the TV, so I'm pretty much stuck at the moment.
The problem of course is that I have no way to capture the TV's state at the instant it fails. So checking voltage levels after unplugging the TV and plugging it back in will likely be futile, unless a component is 'on the edge' or out of spec. I could try operating the TV with its back off and, after it fails, leave it plugged in and measure voltages then, but that would be hard to do as the TV is still in daily use.
Because the TV is still in use, any 'try this, try that' type troubleshooting will be painful, as it would mean pulling the TV off the wall, removing the 10,000 screws from the back, testing whatever new steps are suggested, then, short of coming up with an actual fix, reassembling it and remounting it on the wall. So I'm hoping I can get a bit closer to the source of this problem without having to continually open up the TV.
Update (09/28/2017)
Just an update to my original post:
I was able to locate online a replacement power supply board for my Vizio 42" LED TV (model E422AR). I pulled the back off the TV, removed the old PS board and installed the new one. Everything worked as well as it did before, but the random shutting off problem still occurred. The company I purchased the PS board from were great to work with. They offered me a full refund, or would send me a second board to try, just in case there was something wrong with the one they sent me. I picked option 2 A week later I repeated the process of swapping out my TV's PS board for the new one. Sadly, the problem still occurs.
Here's the thing. I haven't see this problem show up now for almost two months, even though the TV is typically on several hours each day. I don't believe the problem is heat related; there's been plenty of days when the temperature of the room the TV is in topped 80 degrees F. (the vent ports are clean and there's plenty of air flow behind the TV.) I thought this problem might be related to variations in the power line voltage, but my TV is plugged into a UPS (battery), so I doubt that's the cause. I still think this is some sort of firmware bug, but without a way to track firmware updates, there's no way for me to be sure.
Update (11/22/2017)
Another update to my original post...
It's now been four months since I’ve seen a single reoccurrence of my Vizio TV randomly turning itself off.
Given how frequently this was happening to me before - sometimes several times an hour - it is hard to believe this is simply good luck. I continue to use the TV daily, no less frequently than before.
I’m happy to have the problem gone, but have the uneasy feeling it will be back again eventually.
My only explanation for the problem’s disappearance is that Vizio downloaded and installed a new firmware update on my TV that corrected the problem (I’ve always suspected this problem was either a bug in the firmware or could be corrected in the firmware). I hadn’t been keeping a close watch on my TV’s firmware version number, so it might have changed without me knowing it. Too bad Vizio doesn’t inform you when it installs a new firmware update, or makes visible on the Info screen when the last firmware update was installed. Not such a smart TV after all.
Has anyone else had this or a similar problem simply disappear after a while?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
评论:
I too have Vizio with the same problem. XVT553SV purchased in Feb 2011 and has done this randomly from the 1st week I had it. Besides being very limited in what capabilities it has, compared to newer updated models, and a couple of hdmi ports that quit working, it has served me well so far. I have it attached to a APC 1400 UPS for protection. Usually this happens out of the blue with no pattern I can discern once every few weeks to a month and lasts for 5 min. I originally was told by Visio it was updating firmware and of course I drank that cool aid. As it is now going on 6 years old I count it as lucky it still works from what I read and hear from others regarding Vizio televisions so I guess I got my moneys worth at this point.
完成的
Ohhh, that is really bad....
完成的
My TV will stay on for day's but then cut off and stay off for day's. SMMFH
完成的
From below:
Ok, so i bought my Vizio d40-d1 one year ago. Dang it. This mind reading weirdo TV shuts off if i get up from chair and move two feet sometimes. This TV is about 14 feet from chair. Laptop nearby. The Vizio is set for no tracking and is not connected to internet. I do sometimes connect laptop to TV via hdmi cord, but not often.
What makes it shut off like that ? No light either. Is something causing that phenomena in anyway related to the router in other room , TV, then laptop, in a line like that. Right, i know it makes no sense but my moving a few feet must disturb something, waves? , in the space around. I was dumb when i bought a smart TV. Miss my old square 700lb bulky TV. O, back in the good 'ol days - yea whatever.
So, anyone notice Vizio turn off when they move in room ?
完成的
I have the exact problem obviously on other web sites people have said that Visio has sent people the box to update tvs then u send it back to them and it's all fixed! If it's shutting off for awhile like mine did it for about a week then today it went off entirely. It comes on but shuts off tried all the little tricks but nothing but I did notice that as it turns on the logo comes off and it immediately shuts off even tho the Visio light in front stays on but no power light I've noticed. So seeing how I'm in the middle of a blizzard I am going to call Visio tell them what I read on other web site and see what happens keep u posted!
完成的
显示更多的40条评论
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
31个回答
最有帮助的答案
I have a Firestick and realized my Vizio was intermittently powering off and on when I was trying to control my television using the T.V.’s remote or buttons and not the firestick remote. I also tape off the I.R. sensor on the firestick remote or move it so the T.V.’s I.R. sensor doesn’t detect the remote. Problem solved. I don’t know if you’ve got a Firestick or not, but this is how I solved my issue.
I found the answer in this ifixit post: TV randomly turns on and off repeatedly
这个答案有帮助吗?
得分 3
评论:
I don't know about anyone else, but I do have a Firestick. I'll have to give it a try. Thanks!
完成的
Was the same problem for me! Thank you!
完成的
添加一条评论
My vizio smart tv has been doing this as soon as warranty ran out. But unlike the rest, mine shuts off and shows only faint blue light - no logo . Hit the remote power button and all is well again. This is the third house this tv has been plugged into so voltage issue wouldn't seem to apply here. Since mine sits on a corner unit, I may try the fan thing.
这个答案有帮助吗?
得分 2
评论:
Same here 3years old 40 inch this is the 2nd tv in 6 month
完成的
If your tv shuts off randomly, you have something on the same circuit breaker drawing a large current. It's a safety feature cause the tv is not getting the right voltage and thinks it's overheating and shuts off. Mine was doing it until I unplugged my wife's candle warmer from the same circuit and it stopped completely.
完成的
The screen shuts off but with sound still on. Cut off the tv and cut it back on, everything’s fine but within a few minutes the cycle begins again. So I went to the tv menu and reset it. Worked like a charm!!!!
完成的
Same problem,shuts off, no way of knowing if it’s alive or not,since it won’t come on,3 years old,but hardly used,,,solution? Never buy Vizio again.
完成的
I have a Vizio TV just like everybody else and it was doing the same exact thing I found out what is the problem and also found a solution d'accord reads 125 volts usually a black one why I found a white one that reads 100 volts connected it and problem solved
完成的
添加一条评论
Under Settings you will see CEC Settings. Turn off the CEC Function. This will be the root cause off the problem for many people as one of the connected devices is sending an improper CEC signal and causing the TV to turn off.
这个答案有帮助吗?
得分 1
评论:
I've had this option turned off the entire time I've owned my tv and my tv still shuts off occasionally
完成的
I tried that ,i only have speaker and dvd player hooked up.tried turning CEC to disable -it still hapoens unhooked chromecast -still happens ,different plug in entirely different grid in home -still happens... WHAT ELSE CAN WE TRY????
完成的
添加一条评论
My Vizio 4K has been doing this off and on BS since I bought it. It has nothing to do with system, the power supply, software or extras (HDMI, USB, GFI or powerstrip). I think I finally figured out what the problem is… It's the temperature in the room it's in. Mine is hung with a celling mount (hot air rises) about 3 feet from my main entry door. Everytime it would happen of course I would first go check the breaker, which I had to go in and out of my front door to do thus letting cooler outside air in resulting in the problem going away. Not know that me opening the door was what was “fixing" the issue wasn't figured out, by me, for over a year. Thank you all for you input, it has helped me to make the decision to never buy Vizio again.
p.s. mine has only ever been hooked up to “bunny ears”, actually I'm using the old cable coaxial cable that was, at one time, used to supply my cabin with cable t.v. as my antenna. (It's 100+feet long from my t.v)
这个答案有帮助吗?
得分 1
评论:
I just bought my 40" Vizio last week and ughhh. from day 1 screen goes black turns off and on , on its own soooo annoying!!! I've tried each possibility step and still does the same .. Last time I purchase this brand .
完成的
添加一条评论
I have been all over these forums trying to figure out what could possibly be wrong with my tv and nothing seemed to work. House 1 i was on a bottom floor mounted on my wall over a year no issues. House 2 on a wall lots of sunlight with no ac I had issues all day long as soon as spring hit. House 3 I had ac but my tv was between 2 windows I would have problems at certain times of the day and just before sunset. It finally hit me that every time my tv shut off I was also getting up to turn on my ac. I bought a little fan that I keep angled at my tv during the day since the heat/sun seemed to be what was causing it. I did that 6 months ago and I have only had the same issue on days where I forget to turn on the ac and it’s 80-90 outside.
这个答案有帮助吗?
得分 1
添加一条评论
i did a factory reset and put in my zip code and it works now
这个答案有帮助吗?
得分 0
评论:
How do you do a factory reset?
完成的
Hmm i will try that ...
完成的
添加一条评论
Check the back of your TV. Are the vent ports clean and free of lint? Lint build up will impede the airflow necessary for the interiors components. Clean them using a dust wand or a can of air. At some point it'll lead to a blown capacitor. That's noted either by a bulge at the top or a brownish substance. If you're handy with a soldering gun is a relatively easy fix. If not, then you would need to replace the board with the blown capacitor.
这个答案有帮助吗?
得分 0
评论:
I want to thank everyone for their comments - whether true or false ,i finally figured out the fix for us...
Factory Reset... it was a bummer to have to reapply my apps and so on ..but so worth NOT having tv shut off randomly...been 3hrs -keeping my fingers crossed for a few days!
完成的
添加一条评论
So I took mine to a TV Repair shop and it acted just fine but when I got hit home and hooked it up again it started all over. So next time I took it the guy asked me what I was hooking up to the TV and we found that by replacing the HDMI Cable it worked fine.
这个答案有帮助吗?
得分 0
添加一条评论
The person who suggested a wi-fi conflict was right on. We recently had a power outage due to a thunderstorm and the surge completely reset my tp-link router. We finally realized that the problem appeared after the outage. We have ROKU and do not use the smart tv features of the tv, so I disconnected it completely from the network and did a factory reset and, voila, the problem is gone. Everything is back to normal. Hallelujah!
这个答案有帮助吗?
得分 0
评论:
We recently had a small power surge -the condos are replacing power boards ,and after thst a chromecast symbol smfor someone elses kitchen radio started to show up ,i changed those setting....maybe i need to factory reset tv ?????
完成的
添加一条评论
My TV (Vizio d32h-f0 ) I just purchased less than a year ago does something very similar, however i did manage to find out what was causing my issues, but cant for the life of me figure out why.
My tv shuts off and comes back on(without showing the vizio logo) only when i have no audio coming through my TV (Im using a HDMI 2.0 cable, and purchased a second one to make sure it wasn't the cable). I'm using my TV as a Monitor for my PC(Nvidia GTX 1060 6GB Graphics card)
so to keep my TV from shutting off, i contently was running Pandora, or some media. just would put the volume almost all the way down so i could barely hear it.
I stumbled upon a little app that keeps my Audio connection alive without the use of any sound actually coming though. havent had a problem since.
Audio App (windows) :
https://github.com/handruin/spdif-ka/rel...
这个答案有帮助吗?
得分 0
添加一条评论
Mine was the power button on the back that was sticking. I cleaned it up, and pushed it a few times and it was fixed.
这个答案有帮助吗?
得分 0
添加一条评论
I have found that if an HDMI port is bad, or going bad, the tv will turn off. When my cable box was connected to the bad port, the tv would turn off and could not be turned back on easily. Today, I moved the HDMI cable to the only remaining HDMI port that is good. No further problems. I plugged the PlayStation into the port that the tv formerly was plugged. When I select the bad port the tv turns off
这个答案有帮助吗?
得分 0
添加一条评论
My vizio has this same issue my HDMI ports are going out but I found 1 that still works and the TV works fine so I switch back and forth between the directv and the playstation until I could replace HDMI only my port 5 works when i plug in to a different one TV blacks out and it has sound
Hope this help….
这个答案有帮助吗?
得分 0
添加一条评论
My thanks to everyone who posted above. I've had my Visio for about 8 years, use it every day, and never had the power problem until the past few months. I suspected it had something to do with the fact that I'd cut the cord on cable about a year ago. When we were on Comcast cable it never happened, but now I'm using Roku. My other set (a Panasonic) is also on a Roku and it's fine, no problems.
So, based on the advice in several posts, I:
  • Unplugged everything, and pulled the Roku out of the HDMI port.
  • Plugged the Visio back in, then did the factory rest (picked Menu on the remote, System 》Reset&Admin, then skipped all steps that involved connecting the tv to a network)
  • Plugged the Roku power back in on the same extension cord (limited outlets available) and then plugged it into the HDMI port
  • Used the Visio remote to select the Roku as Input
It's now been running for several hours with no shutdown! YEAH!
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, but I figured it out for myself. So before you spend money on repairs here’s what I did.
If you tried uplugging your TV and holding the power button down for 10 - 30 seconds and plugging it back in the wall and that didnt work, try this method that I discovered on my own:
1). Hold the ON button in on your Vizio TV. Do not release it
2). Press the menu button on the remote control and select SETTINGS
3). Select RESET
4). Follow the steps to reset your TV.
This should work. Mine works just fine.
这个答案有帮助吗?
得分 0
添加一条评论
I have a E3d470VX that is probably like 7 years old now? (typing this in 2019)
I had this issue when i origially got it, and it started happening a bit again now, years later. I just got a new router and connected the TV to the wifi for some dumb reason even though god knows I am not using 7 year old vizio apps. Support for the “being netwrorked f’s up old vizios with a memory leak or something” theory
这个答案有帮助吗?
得分 0
添加一条评论
Mine started doing this recently, it's kind of an old tv but hasn't been used much, it acts like it was turned off with the remote, there has been a few instances were it wouldn't cut off too, with the remote or power switch, might be a direction to look in for those who have already replaced the power supply board.
这个答案有帮助吗?
得分 0
添加一条评论
I have a Vizio E55-F0/1. It would randomly just turn off. It wasn’t very often, but it happened and was annoying. I started to try different things. Someone mentioned the CEC setting and that it should be disabled. When I disabled it, it shut off more often. But I noticed that there were three options, enabled, disabled and ARC. When I looked at the back of my TV, my cable (actually Google Fiber) was plugged into the HDMI 1, which was also labeled [ARC]. So, I went back to the CEC setting and selected the ARC option. It’s been several days now and it (knock on wood) hasn’t shut off on it’s own yet. Since I’m a little OCD, I always put my cable/Google Fiber or whatever in HDMI 1. I have 4 Vizio TVs and this is the only one with CEC and the only one that shuts off by itself. I hope this is the solution and that it helps others!
这个答案有帮助吗?
得分 0
添加一条评论
I have a Visio E65-EO. It started going on and off and I cannot get to settings to try different fixing options. How do I get it to turn on and stay on.
这个答案有帮助吗?
得分 0
评论:
I'm assuming you can't get to your settings because the TV won't stay on long enough. I don't know if this will help, but it's worth a try. Unplug your TV, then move your input (cable/satellite/Google Fiber or whatever) to a different HDMI input. Plug your TV in and see if it will stay on. Good luck!
完成的
添加一条评论
Ok I’m not impressed with this Visio but that being said it happened when my fire stick was in port 4.
i replaced hdmi cord
i detached fire stick extension for hdmi that’s the little piece if your hdmi is hard to access.
Disconnected the newer voice remote and went back to the firetv app.
turned off Bluetooth speaker
ok so now it works. Wow this is such bleep bleep.
这个答案有帮助吗?
得分 0
评论:
Also changed the ports a few times Vizio in my Opinion is junk
完成的
Just did this after trying everyone else’s advice and taking the batteries out of the fire stick and replacing them actually worked!!!!
完成的
添加一条评论
Seems like a lot affects this tv. Mine had that same problem. I had it set to WiFi and it kept powering off. I Plugged the internet in with an Ethernet cable and it seems to be working now.
这个答案有帮助吗?
得分 0
添加一条评论
Always suddenly my TV just started jumping from one channel to the other like you watch a movie and then like 5 minutes or 10 minutes later it jumps to another Channel then I'll jump to another Channel and I did everything that they said to do. I unplug it I turned it off I even turn off all the electrical box to my house and it's still doing the same thang. Please please help. Lupe Martinez
这个答案有帮助吗?
得分 0
评论:
Hi,
Do the channels go up or down when it jumps or is it random?
What is the signal source, antenna or a cable box?
Try removing the batteries from the remote control and see what happens.
完成的
添加一条评论
There are a lot of different problems here, but mine (reported 10/14/19) was where the TV would turn off randomly. I tired several different things and it would still happen multiple times a week. Out of desperation, I decided to unplug my TV and then plug it back in once a week or so. I’ve been doing this several weeks and the only time my TV turned off is when I forgot to unplug it. That got me to thinking. I have my TV and all my components plugged into a power strip. It’s not a very good power strip like I’ve had in the past. I’m thinking that maybe the TV is pulling more power than my power strip can handle. I’m not an electronics person, so this is just a thought since unplugging it seems to be working. I’m going to purchase a more specialized power strip and see if that helps.
这个答案有帮助吗?
得分 0
添加一条评论
TL;DR Take out the batteries in your firestick remote, it could be turning on/off your tv!
We have a 55 inch vizio tv and this power cycling issue was happening to us. We tried all the button holding and unplugging methods suggested in numerous posts, to no avail.
We are fix-it types, so we decided to disassemble the tv down to every last screw to check for a possible fried hardware issue. Nothing there either. We were considering replacing the power board until we read this post…Finally came across someone in this thread saying it could be an issue with the firestick remote and EUREKA! Taking out the batteries of the remote and putting them back in fixed the problem! Not sure how long this quick fix will work, but glad to know this was the solution before we spent money on a (or many) powerboard(s) or even a new TV. Thank you to those who suggested it! Hope it helps others!
这个答案有帮助吗?
得分 0
评论:
I made an account just to tell you that this worked. Thank you so much.
完成的
添加一条评论
Check your timer settings!
It’s not much and might not fix anything for some of ya, but my tv was turning off at seemingly random. I decided to comb through all the settings just in case and landed on my timer settings. Sure enough, the auto shutoff is set to turn my tv off 10 minutes if no signal is detected.
No idea what counts for a “signal” though since I was definitely watching tv whenever it shut down. Maybe because I was using the fire stick?
这个答案有帮助吗?
得分 0
评论:
Thank you all!! If I'd not read to the bottom of this page I'd never have learned that our Roku stick (sitting on OFF nearby) might be the culprit. We removed the batteries, and Voila!! Our old Vizio is back!!
完成的
添加一条评论
Has anyone had the shutdowns and tried putting tv in Store Demo Mode? Mine ran great two straight hours last night once I switched mode to Demo. Back to Home Mode today and lots of shutdowns. Vizio support won’t help or acknowledge issue! Wonder if it is something with Network Connection or WIFI board.Demo mode doesn’t use Network as far as I know. Any other ideas?….
这个答案有帮助吗?
得分 0
评论:
It’s not my timer setting for 10 minutes or Roku Sticks....already ruled those out.
完成的
添加一条评论
After reading most of the posts herein, my husband and I discovered there is an apparent radio transmission conflict between ANY and all Roku, Amazon Fire sticks, etc., with one another. And when we take the batteries out of our Roku stick, the problem immediately stops. So if we watch regular network programming, we remove the batteries from our Roku. Perhaps someone more eloquent in such conflicts can better explain. For now, 100% of the time when we forget and have multiple Vizio remote controls present in the room, they cause our Vizio's to begin acting erratically. Simple fix, not so clear explanation. And we can't figure out why it took awhile for this to begin happening, however. No doubt it has something to do with RF.
这个答案有帮助吗?
得分 0
评论:
I wish it were that easy. I took all remotes out of the room nowhere near and have tried battery removal as well. It seems to be something in display settings. I can get tv to stay on longer intervals depending on settings and tweaking, but haven’t found right combination. I almost can get it to stay on for an hour some times without turning off. Other settings it turns off very quickly and more often.
完成的
添加一条评论
So far it’s been only a couple of days, no problem yet. My TV use to reset itself 5 or 6 times a day. all I did was to put a fan behind the TV. so far so good. If this works, I will install a USB to the TV.
这个答案有帮助吗?
得分 0
评论:
Yea I could see that may solve. I was thinking to use some heat like blow dryer or freeze spray to try to isolate the board and then component. It’s probably on the main board like IC or some video processor, because changing my video setting can make it worse or better it seems. Can pt get rid of it completely though. Right now I put it down in colder room in cellar and it shuts down about 2x per first hour. Not too awful, but still annoying.
完成的
添加一条评论
I have this problem when I'm using one of the movie apps. I believe it's the ‘cable tv ‘ ( mine is Direct tv) that's turning it off. I turned off that box and it stopped. So far so good.
这个答案有帮助吗?
得分 0
评论:
Thank you for your response, snolou2. We do not have satellite service; we only have an antenna. Live way out in the boonies. Our TV is ten years old. Prolly should have lasted longer but, oh well. We tried everything. Even took batteries out of our Roku controller which helped for six months (Vizio did not “like” the Roku remote controller being close to Vizio remote). But TV won’t come on at all now. Guess new technology w/ solid state mother board, has shorter lifespan than old tube technology. At least it old tech could be repaired. Best to you for kindly replying.
完成的
添加一条评论
I have the px75-g1
My TV would Turn off on it's own.
I check settings and timers were set to auto timers was set to 10 minutes. I turn that off. Hope it works
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
I have a Vizio 65” TV and have been dealing with powering off issues for 2 years. I've searched Google and YouTube for solutions with no luck. Finally one day, it's like the fix just fell in my lap. Here's the solution that has worked for me. My TV has worked fine with no shutoffs for the last month. First, unplug your TV from your surge protector and hold the physical power but on the TV down for 20 seconds and then plug it directly into the wall socket. Next, do a factory reset. Now you enjoy your Vizio TV until we leave Vizio for good because I will NEVER EVER buy Vizio again in my life!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Laba 将永远感激不已
浏览统计数据:
过去的24小时: 119
过去的7天: 882
过去的30天: 4,121
总计 189,439
