跳转到主内容
Guides and support for devices that play video from DVDs.
286 个问题 查看全部
DVD recorder/player suddenly not reading discs.
Re: My Panasonic DMR EA14 DVD recorder and player: DVD discs I've recorded & finalized myself on the Panasonic, & watched many times, suddenly not able to read/play. Error message: "Unsupportable Disc." Discs DO playback on my MacBook, & the Panasonic IS playing store-bought, pre-recorded DVD's. Also, suddenly having some difficulty recording on discs with previous recordings on them & plenty of recording time left. Hope someone can help. Thanks very much. - Julie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
my Panasonic recorder, DMR-EZ45V , suddenly can not read DVD discs , any suggestions how could I repair it myself ?.
Many thanks in advance
Mati Basis
mnbs53@tiscali.co.uk
0208 444 7833
完成的
I have the same problem with my Philips DVDR 3355 :(
any suggestions? I cleaned the laser head but still the same
完成的
添加一条评论
3个答案
Try to clean it with dvd cleaner disc
这个答案有帮助吗?
得分 0
1条评论:
Thank you very much. I will try that.
完成的
添加一条评论
My Deawoo is the same - one month after warranty ran out. Will not recognise even some pre-recorded discs , and cleaning with "Laser Head Cleaning Disc" does not work. I took it apart and wiped the laser head gently with optical cleaning fluid - still the same. I think must be some electronic fault, which is too expensive at repair shop - so just buy another! (Second hand ones are cheap)
这个答案有帮助吗?
得分 0
添加一条评论
Could be a simple mechanical/dirty grease pb, see my post here :
will only paly home burned DVDs
(or maybe http , no "s")
sorry, I have to go for now ;-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
llebrew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 12,951
