Intermittent starting problems - Passat V6
Occasionally the car won't start. Not electrical - battery good starter good. It usually (always) happens when trying to start the car within a few minutes or hour of having recently run - like won't start after stopping to fill gas or won't start after driving to eat lunch. It will start if left alone for many hours. It seems to start when the engine is cranked for 10 or more seconds and the accelerator is pushed and held to the floor. When it starts there is a strong smell of fuel - indicating that the engine was flooded. The "accelerator to the floor" solution does not always work and usually does not work the first time.
18条评论
I have a 2002 VW passat 4motion.
It won't start but it does crank.
Then it will start.
When running it stays running and I have
no problem with it.
Why dies it do this?
Thank you
由 chris 完成的
2002 pas sat v6 2.8 auto gas we replace trunk opener switch, then fuel pump not work or door light not flashing no car not start need help, we check fuse fine , i went school please help soon contact send message jashan06@hotmail.com
由 jashan 完成的
Test coolant temperature sensor- or engine temperature sensor.
由 Monica Reissland 完成的
Can someone tell me where is the fuel pump on an 02 Passat Wagon 2.8 how to get to it
由 José Rodríguez 完成的
I have a 2004 passat 2.8 V6 the ac, horn and fog lights dont work can someone tell me the problem?
由 Torrance 完成的
显示更多的13条评论
