Wifi is disabled and cannot be re-enabled
So recently my Chromebook was not connecting to any networks. When I went to look at the connections, it said that the Wi-Fi was turned off, and the button to turn it on was not present at all. Upon clicking on 'Settings', the Wi-Fi network was listed as 'Disabled', but when I went to click on it, it does not give any options to re-enable it. What's wrong with it?
5条评论
Why my chtome book is not connent to wfi
由 kimberly grace brown 完成的
Why. Chrombook is nor connent to wfi
Same issue here. I've tried to power off, powerwash and reset many times without much success. Then I took the laptop to my local PC shop. The technician opened the back, removed the Wifi card, cleaned it and screwed it back tightly and it’s been working fine since then.
由 Raymond Robert 完成的
It's may chrome os's bug, try to press ctrl + alt + T open the crosh tab then enter "rollback" to rollback to previous version.
由 Chauncey Xiao 完成的
Took out wifi card and cleaned it and re-seated it, fixed the problem.
由 Jeff Nagy 完成的
