跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1574 个问题 查看全部
Why/how does vertical lines just fade away?
Hi!
No problem here, just asking a question. I changed battery+screen on my 6 plus, after that i hade 4 vertical lines running along the screen. Now, 2 days later the lines has just dissapeared. How does this happen? Why? how does it work?
Im happy that the lines faded away, just confused as of how..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
1. Bad Connection
Reason: first thing you should do is check the connection between the flex cables and the logic board. If the connectors are obstructed by dust or debris, try to clear them away with a brush and rubbing alcohol. If the connectors are damaged or the flex ribbon is bent over 90°, well, a replacement is needed. After checking those, reconnect the flex cables to the motherboard, making sure the connectors are properly connected.
Solutions: do not force the connectors together until you are sure they are properly lined up; do not bend the flex ribbons during testing and installation.
2. Static Charge
Reason: aside from a bad connection between flex ribbons and the logic board, ESD (Electro-Static Discharge) is another big cause of vertical lines. Too much ESD produced by either the product itself or by human during the test or installation.
Solutions: reduce any static charge by using a body static remover (or touching a ground) before proceeding with any testing or installation. Wear an anti-static bracelet and keep an ion fan on during the repair job.
3. Damaged IC
Reason: possibly the IC on the display is damaged if both of the above methods don’t help. Check the part on the top left and right corners in particular. If there’s any damage, or one of them has been crushed or the IC has been damaged then your part is defective. You’ll have to replace the screen with a new one.
Solution: the screen has to be replaced if the IC was broken. Do not squeeze the IC to avoid damaging it.
Lastly, be sure to use an extension flex to test the screen before reassembly to prevent unnecessarily folding of the flex ribbons, as well as to prevent damage to the fragile connectors.
Hope It Works
Thanks
Varun
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henrik Engdahl 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 382
