跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
My sreeen doesn't want to turn on after sreeen replacement.
My friend gave me his iPhone 5c to change the sreeen it had water damage but it still work. When I change the sreeen the sreeen didn't even turn on . It been connected to iTunes it reconized it but still sreeen won't turn on what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
As Jason mentioned, use isopropyl that is a minimum of 91% (ideally 99%) and see if there is a difference after it dries. You can also plug the original display back in to confirm if it is a problem with the phone or if you potentially just got a DOA screen. I would advise against working on any type of water damaged device in the future without a proper ultrasonic cleaning because of issues like this or similar arising afterwards but since your already in, I hope you can get this figured out! Keep us updated!
这个答案有帮助吗?
得分 3
1条评论:
Very well put. Water damage is a tricky thing but can be resolved if taking the proper steps
完成的
添加一条评论
try to clean the connectors with some gasoline and an old toothbrush on the mainboard and see what happens when you plug back in the lcd. don't forget to cross your fingers!
这个答案有帮助吗?
得分 0
添加一条评论
Gasoline? Really?
Clean the connectors with isopropyl alcohol (99% if you can) and a soft brush toothbrush. Blow out the board of any debris that may be there and try again to connect.
Let me know if this was helpful or hot
Jason
Device Savers - Tampa
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aldo madrigal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 13
总计 65
