How to Reinstall EMI Shield after cleaning
iphone 5, I have reason to believe that the logic board has water damaged parts under the EMI shield.
how would I reinstall the shield after removing and cleaning?
Clean up or flatten out all the shield solder joints with a soldering iron and wick if you need it. Slip the shield back on and use an iron to solder the points again. You don't need to do a perfect job on every single joint. It helps if you try an avoid prying/bending the shield during removal.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
1条评论
Read the answer below.
由 icaremore 完成的
