跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Long screw damage repaired but error 4013
Hey :)
I repaired a long screw damaged iPhone 5 today but when I want to update it (because its in recovery mode) it appears with error 4013...
-Im using a dc power supply
-I tried other cables, ports and pc
I had the same problem with 2 iphone 5s...
I repaired a long screw damage on the left bottom ( NOT Bluescreen Hole!)
Iphone had redscreen and after the repair ive not seen the redscreen anymore but both of them have also error 4013 problems...
What can i do?
Is it a nand problem?
On every iphone i can see the serial number when plugged in to itunes, so the nand is good or not? Can it show me the serial number and be damaged too?
What can i do else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
The only thing you can do is recheck your repairs and look for loose loose joints and damage you may have missed the first go around. On the first picture there looks like a trace that has not been touched up on the left side. Do you have any pictures where the repairs are cleaner?
这个答案有帮助吗?
得分 0
添加一条评论
The red screen of death. Classic. Try disconnecting the front camera/proximity sensor cable and see if it works after doing a hard reset also.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mikail 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 460
