跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
Motherboard powers off after 10 seconds of boot.
After I shutdown my laptop, I turn it on a while later and it powers on but then goes off after 10 seconds and doesn't show anything on the screen. No sounds or anything only the fan spins. The lights work perfectly and the motherboard receives power. So why, after all my good deeds, why is this happening to me. Please help me someone so that I may work on my unreal engine again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Im not sure if this helps, I know computers will shut off if overheated. If I were you I would open the laptop up using a guide. Check the condition of the thermal paste on the CPU and replace it. Also be sure to blow out some of that dust once you're in it.
Hope it helps, Good luck!
这个答案有帮助吗?
得分 1
9条评论:
I already did that bruh any other info I would really appreciate it.
完成的
I tried everything I know possible please help.
完成的
Do the lights stay on or does EVERYTHING power off after 10 seconds?
完成的
Everything powers off please keep helping.
完成的
When turning on, look at the lights do you show any blinking sequence at all?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
j.bernard2002 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 100
