跳转到主内容
An 8 inch Capacitive Dual Core Zeki Tablet with dual cameras. The model number for this device is TBQG884B .
11 个问题 查看全部
loading apps on sd card
After I reset tablet I was putting my apps back on SD card ,but I have 3 that will not load when I try to load them it says couldn't move app,.There is 4.2 GB of storage space on the card,but my tablet is running out of space.What can I do ,? HELP
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Problem solved thanks
完成的
添加一条评论
1个答案
已选择的解决方案
some apps will not go onto the sd card and some apps will only partially go on the sd card. this makes for some problems when you reset a phone. if the app wont go on the sd card then when you reset the phone you lose the app. if the app partially goes on the sd card when you reset the phone you lose a part of the app. there is really nothing you can do to solve this without rooting the device. about the only thing you can do is get a cleaner app like cleanmaster and constatnly clean your storage or figure out which apps you are not really losing and delete them. i hope that this helps and you are able to get all of your apps working again.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jetherton1949 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 189
