MacBook Pro (Early 2015) Retina 13" Display Black Screen with Chime
Hi there -
The display on my Macbook Pro (Early 2015) Retina 13" is black when I turn it on - I hear the chime, the keyboard backlight still works, sound works. But I noticed that the backlight on the Apple logo does not turn on.
I've tried everything that was recommended by others - such as trying the PRAM reset and resetting the System Management Controller. But no luck here. I was able to log on briefly with the screen display working correctly - weirdly, it asked me to select a language and prompted me to answer why I was having trouble logging in. I didn't really pay attention to all of this as I was just eager to log on.....
I took it to the genius bar yesterday, but they said it could be a display issue that would need to be sent in for repair. I have a little hope in me that this can be fixed without having to spend $500 - a little upsetting that I've had this for less than 2 years.
Any guidance, tips, fixes are welcome. Thank you so much in advance!
10条评论
Having the exact same problem sometimes the screen would work and then flash random colours or be perfectly fine or then just go dead
由 Kealan Clarke 完成的
If you shine a flashlight through the apple logo into the Lcd while the screen is on, do you see anything on the LCD at all? If so, then there is an issue with the LED backlight for the computer, which is a common point of failure particularly if the laptop was liquid damaged.
由 https://vancouvermac.ca 完成的
I do see the screen if I shine through the apple logo. Ah, that's helpful. Thanks.
由 rspark16 完成的
Just got mine repaired under warranty, the motherboard had gone
由 Kealan Clarke 完成的
can any1 show me the backlight fuse location in logic board
由 dipkenyum 完成的
显示更多的5条评论
