Battry not detected after screen replacement
Replaced cracked screen on Surface pro 3 and now the battery isn't detected, tried doing updates in windows, it will sit and restart every 15mins to do a firmware update but will never complete and continually restart, tried uninstalling the driver from device manager for the battery, tried just letting it charge, tried the power button and volume up button for 15 seconds or longer.
any other suggestions?
4条评论
Are you using an original charger? Did you make sure the pin layer thingy for the battery and LCD connector are there and are not upside down?
由 Ben 完成的
had to purchase a new charger, it is a microsoft brand surface pro 3 charger, as far as im aware there's only one pin layer for the LCD connector not for the battery. if i am wrong let me know.
由 joshr45 完成的
Actually the battery one does. Because the battery connector and LCD connector on the board both have a bridge connector that is supposed to be placed.
https://ae01.alicdn.com/kf/HTB1AEk9KpXXX...
The battery one uses a different one so they are not the same notches and pinouts.
由 Ben 完成的
not seeing a picture there from your link, but i checked it out on ebay, will check tomorrow if the part is there or lying around somewhere, thank you.
由 joshr45 完成的
