跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
359 个问题 查看全部
Can't find a chat headset which works
i have bought several chat headsets which were all recommended for the xbox one s however none of them seem to work. they work with a normal xbox one but not the one s.
i have even had the console replaced incase that was the problem but the headsets do not work with the replacements either. please help x
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try this.
http://www.bestbuy.com/site/microsoft-xb...
这个答案有帮助吗?
得分 0
评论:
hi, that is the headset i bought but it will not work on the one s . tried on several one s consoles and it doesn't work but it does on a normal one console. thanks though ..
完成的
添加一条评论
You should consider buying; the generic one at Gamstop/EB Games. If they faill to work I would consider seeing the controllers headset port as the issue. Try using one that you have, around the house or purchasing a new one, or attempt to fix it yourself via dissabembly (do not attempt if not confortable doing it, or without knowledge)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
geordierichardson 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 80
