跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Screen is completely dim.
Hello.
My screen suddenly turned all dim. I can see a bit if i point a flashlight at the screen.
Works with external display. (HDMI and apple tv wireless).
Was told by my local repair shop that it would cost 500$ and 5 weeks to fix it, which did not sound like something i'd like to do............
Anything i can do myself to fix this. I have great experience with repairing iPhone and iPads.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Will most likely be either the screen pcb, screen cable, LCD connector, backlight fuse, backlight IC, backlight IC feedback trace, or a combination (maybe even none of these).
If you have experience microsoldering, and have the required equipment, grab a schematic and board view for your model. If not, send it somewhere.
这个答案有帮助吗?
得分 2
添加一条评论
Well... Yes & No ;-{
You may have blown a fuse link seen here marked in Red:
But there is a reason it blow if that is the case. I would recommend you investigate the root cause before replacing the fuse link. You'll need either a micro soldering iron or heat gun as well as get the correct replacement part.
The other possibility here is the Buck Controller which powers the backlight LEDs has blown. I often see this happen when something was spilled into the keyboard. The chip is on the backside of the logic board seen here marked in Blue:
If you don't have the tools I would recommend you let someone deal with this.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Niels Aasted 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,362
