Loud clicking during agitation cycle
My Kenmore 110. 20702 991 top load washing machine is making a loud clicking noise during the agitation cycle.
I have narrowed down the noise to the area beneath the washtub. There are many components here, gearbox, motor, pulley, pumps, etc.
Lights connected to the same power outlet dim at the same rate and time as the clicking noise.
Spin cycle, filling cycle, etc are unaffected, just agitation has this issue.
Trying to narrow it down further to find exactly what I would need to replace.
7条评论
@sirprime "Lights connected to the same power outlet dim at the same rate" something drawing to much power. Post some images of what your transmission and pulleys look like. Use this guide 在已经存在的问题里加入图片 for that. It will allow us to see what you see. Any chance you can post an audio of what you hear at place like you tube etc. Or you can post a video with audio by using the same guide listed prior.
由 oldturkey03 完成的
@sirprime, I have a Kenmore 90 serious with the same problem regarding a clicking sound after the spin. Would I use the same fix as you described above?
由 Roger Dana 完成的
I had the same problem...loud clicking, lights dimming with each click, barely agitating...changed the motor coupling, put it back together and started a "pretend" load. So sad. Still doing it. At least the part(s, 3 piece) wasn't expensive, but I can't afford a new washer. Any other suggestions? P.S. Turned on the washer again a few hours later and zipiteedodah, it's working fine! Don't know why, but I'll enjoy it while it lasts! Thanks for your help....wouldn't have known WHERE to start!
由 Eisenhour 完成的
I have the same problem, from the start, Sears came out several times, kept blaming it on floor, it vibrates something awful and you can hear the gears change, a very loud machine. I now have a new floor, still doing it, no longer under warranty, 3 years old, not sure worth fixing.
由 Bev 完成的
I have a similar problem. In fact, I purchased a 1-month old Kenmore laundry center (417.97962705) with this problem. The previous owner also had it serviced twice, gave up and sold it. Sears even changed the transmission and still didn’t solve it! I believe I now understand the reason for noise that sounds like plastic grinding during the rotation portion of the agitator’s rotation-rest cycle each second. I think the noise is the agitator’s built-in mechanism that prevents excess torque on the transmission from an overload. I’ll bet a short-sighted design iteration which intended to increase the efficiency rating (use less water) for the laundry center is to blame. If I run with only water, no noise. More often than not, if we do any load size without adding additional water, the noise is there. Manually adding a few more inches of water makes it stop. I have always wondered if the water level/pressure sensor can be adjusted to allow more water. Some units have an adjustment screw on them. Someday I'll have to take mine apart and see.
由 smart networks 完成的
显示更多的2条评论
