跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why can't I completely close back panel? Not a prob previously.
I can’t get the back plate into place. That last couple of millimeters the lower edge of the plate slides down to line up with the bottom edge of the phone.
Didn’t have any trouble closing up after replacing the front screen. I had to open it up again when I realized I had missed the spacer under the top of the battery connector.
Now I can’t get the back panel to slide into place, closing up. Ready for 2 pentalobe screws, finishing this repair.
What am I forgetting or overlooking that I didn’t the first time? I’m almost positive the only thing I took off was the screws and the battery connector.
I doubt the Russians snuck in and messed it up somehow...so it must be something I did, not noticing...Maybe something shifted?
Everything looks fine. Nothing appears to be sticking up or out and getting in the way of full closure.
This is maddening. Help!
ThankYou!
-Mike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I have always had that problem with that series of iPhone. There doesn't seem to be much reason or rhyme with it. It doesn't always happen with each phone. You basically have to retry repeatedly, and use gentle force doing this. Eventually you will get it to slide perfectly into place. I agree, quite maddening
这个答案有帮助吗?
得分 4
1条评论:
Thanks for the info. Eventually, the %#*@ thing closed. It was definitely an exercise in frustration.
Of course, the next time I opened the %#*@ thing, it closed right up. No problem.
I guess the iPhone gods were just giving me grief as a newbie iPhone user. Hopefully they won't give me any trouble when I eventually get to replacing an iPad front glass/digitizer assembly. My glass being half-empty, tells me It'll be a hassle! :-)
完成的
添加一条评论
添加你的答案
Mike McIntosh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 67
