跳转到主内容
加入维修社区 - 创建账户
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
Why does my Sony ICFC1 clock flash "OFF" on display & not keep time?
My Sony ICFC1 alarm clock has been continuously flashing between the time and "OFF" on the display. Also, the buttons on the back to set time do not correspond with one another.
why would my clock flash this way, also flashes cycle of date as if setting time and has been keeping incorrect time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
my guess the battery needs replacement????????????????
完成的
Tried everything suggested and nothing works. All I want is the correct time.
完成的
Just purchased cube clock radio. Can't get time set to am. No matter what time i set its pm!
完成的
@Ann Hearn
What is the make and model number of the clock if it is not a Sony ICF-C1T?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Try a power reset and see if this resolves the problem.
Turn off the AC power to the clock.
Remove the coin cell backup battery from the clock.
Press and hold the Enter/Time Set button for 10 seconds and then release.
Reinsert the coin cell battery and then switch on the AC power and see if you can adjust the time etc.
Here is a link to the user guide for your clock/radio which shows how to remove the coin cell battery. Ensure that you insert it back into its' holder the correct way if it happens to become dislodged when out of the clock.
https://www.appliancesonline.com.au/publ...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Andrew Arruda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 8,173
