Power steering fluid or ATF-4 for the power steering unit?
Check the cap of the power steering fluid reservoir or possibly the side of the power steering fluid reservoir. There will probably be a sticker or raised/engraved letters indicating what fluid to use. Also, you can check the user manual-the fluid spec will definitely be in there.
这个答案有帮助吗?
yes to Andrew, or call any dodge dealer. The oem spec is best if you want longevity, but if your penny pinching, and its a beater the ATF is fine. they are essentially the same, with slightly different additives.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,733
