跳转到主内容
July 2013/ 1.0GHz ARM single core/ 4GB SSD/ 512MB RAM/ Android 4.2
12 个问题 查看全部
How do I reset my tablet when I don't remember the password
I can't remember the passcode I need to know how to reset my tablet
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 123
22条评论
I factory reset my nuvision 8solo tablet but I don’t remember the email or password to get back on it. So I can’t get passed that email verification part
完成的
My tablet is fixed but I forgot the password to get on it.
完成的
Basically my 8-year old daughter got Easter iPad Acer iPad add she hasn't been on it for ages she was using her thing but it got stolen using her phone but got stolen I was up till 5 this morning trying to sort it out and all Tito until now it's saying I got the right past it's saying I got the right email so I keep resetting the password and then it tells me to log in the email address again then when I do that tells me to log in the past word again I'm not worried about losing anything on there she just wants to go back on there to Claire games please can you help thank you you
完成的
I was given a Tablet A from my partner and I put in a password but I can’t remember my password
完成的
I can’t remember my password for my android trio. How do I reset that?
完成的
显示更多的17条评论
添加一条评论
19个答案
已选择的解决方案
@chrissy568132 , Chrissy you may loose all data if not backed up prior. You can try to factory reset. With tablet off, press and hold the power and volume up buttons simultaneously. Hold for 10-15 seconds, this should enter into boot menu. Then you will find an option to, Reset Factory default settings/reset user data. select this option. Device should now reset and clear password. May take a few minutes. Good luck.
这个答案有帮助吗?
得分 80
43条评论:
more...........................
完成的
Thank you!!!
完成的
my tablet wont turn off unless i have the password what do i do?
完成的
I did itbgrern words fastboot came up but nothing to restart it just the words fastboot in green can't do anything else
完成的
Well i held down turn on and up volume when it came back on greenwood fastboot came up now it won't turn off nothing probly let it go dead but it's stuck now?///
完成的
显示更多的38条评论
添加一条评论
Hi I can’t remember my password. To unlock my Samsung table. How can I change it.
这个答案有帮助吗?
得分 35
8条评论:
Need new password or preferred old forgotten code
完成的
Nabi, have forgotten password for mummy mode, have rest still locked can't get into mummy mode it's still locked
完成的
Can anyone help me
完成的
My friend gave me a RCA tablet she factory reset it and it want take my email or password
完成的
Thank you so much I've been trying to get back into my tablet for about 3 months at times I wanted to just throw it through a window.
完成的
显示更多的3条评论
添加一条评论
tablet is asking to start android enter your password but it does not allow me to type in anything also can't remember password when I follow instructions on turning off nothing happens takes me back to to start android enter your password but no keyboard to enter or type anything please help. This is a supersonic sc_1010jbbt 10 .1” tablet with Android OS 8GB thank you so much
这个答案有帮助吗?
得分 9
9条评论:
I have a icraig tablet. I forgot password pin number and can't reset it. When I hold down the power button and volume up button it says no command and won't let me do anything else. Someone please help me.
完成的
I forgot my password
完成的
my daughter's got Acer iPad it was about 2 years ago when she sey her email and password can remember email with reset the password about 10 times that keeps going back to email we got type it in and it goes back to password we got a type in it keeps going backwards and forwards can you give me some advice please
完成的
For gotten passward
完成的
I try resetting it but say wrong past word
完成的
显示更多的4条评论
添加一条评论
I pressed & held the up button and power for 15 seconds. It's now showing “No Command”? What do I need to do now, please someone help. Thank
这个答案有帮助吗?
得分 9
添加一条评论
I am getting a new samsung tablet, I would like to change my password for my new one! Do I change the password on my oldone first then put the new password in my new tablet?
这个答案有帮助吗?
得分 8
2条评论:
Forgot my pattern but remember my password, do I have to factory reset? Just curious cause I got it for my son and downloaded all the apps he uses already. This is a new galaxy tablet btw.
完成的
i had to do 1010 my password was 0101
完成的
添加一条评论
Hi i have chuwi tablet windows 10. The samsung or microsoft on first opeing lock me out no matter whT password i try it wont reconize. Help how can i reset the dam thing ☺
这个答案有帮助吗?
得分 8
添加一条评论
I need to reset my tablet
这个答案有帮助吗?
得分 7
1条评论:
I did but need help
完成的
添加一条评论
How do I stop having to enter password to open
这个答案有帮助吗?
得分 6
3条评论:
5/15/2020...I have that same problem! Please help!!
完成的
that's the same as NI I've got the email right they keep telling me to put password and I got keep doing it until now and nothing is happeningplease help is a hater one to really lose you just please a ROBLOX games and things like that on it
完成的
Same problem
完成的
添加一条评论
I've can't get in to my tablet joy tb I had to set my tablet now I can't get in to my tablet can you in my apps my screen
这个答案有帮助吗?
得分 5
1条评论:
Hi I forgot my password to open my alcatel joy 2tab can you help me???
完成的
添加一条评论
I can't get because I went to reset it, didn't let me 2 cause, it was blue when I got it and I couldn't do anything.
这个答案有帮助吗?
得分 3
添加一条评论
Hi am trying to get into my Samsung Galaxy tab E and I've tried to hard reset it that didn't work and I've tried to turn it off to try it again but when I turn it off it asks for the password but I don't know the password what do I do?
这个答案有帮助吗?
得分 3
1条评论:
I have a bg2-w09 tablet and it's asking me after resetting it what was my email address how do I fix that
完成的
添加一条评论
Yesthe need to be
这个答案有帮助吗?
得分 2
添加一条评论
You can go into google and search up password changer and fined a good one and it will let you change it.
这个答案有帮助吗?
得分 2
1条评论:
Didn't work properly for me but thanks for sharing that advice. I depressed the tiny recessed reset button with a pin with the screen on which forced the reset. I'll have to set it up again but at least I can use it now.
It's not something used frequently so I forgot the pattern. I'll be using alternative security measures in future 🙄
完成的
添加一条评论
I have a bg2-w09 tablet and every time I reset it it's still coming up previous email address what do I do
这个答案有帮助吗?
得分 2
添加一条评论
Anyone know how to how to get into town without using a password
这个答案有帮助吗?
得分 2
1条评论:
O bought a nokia tablet and it is set with a password. don't know the password everything to set is return to password. how do I open my tablet. or get the system bios and settings area. or what can. I do to disable a password. howvtonopen up my tablet inside also. I have nonfset of number keys is their a system set of ctrl keys.
完成的
添加一条评论
I wunt to no how to fix my tabiet
这个答案有帮助吗?
得分 1
添加一条评论
Thank You so much really appreciate it
这个答案有帮助吗?
得分 1
添加一条评论
Verification code I don't remember what number I use how can I get in my tablet to fix it
这个答案有帮助吗?
得分 1
1条评论:
Help me please
完成的
添加一条评论
I have a dialn 8x ultra that wont reset and i cant remember what the password is
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chrissy 将永远感激不已
浏览统计数据:
过去 24 小时: 44
过去 7 天: 389
过去 30 天: 1,593
总计 164,225
