跳转到主内容
Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
1089 个问题 查看全部
No audio output device installed
There is no audio output device installed on my Yoga 710.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论:
Hi,
What OS is installed in your laptop?
Is there an entry listed under Sound, Video and game controllers for an Audio controller? If so is there a red cross or yellow exclamation mark next to the entry? Go to Control Panel > Device Manager > Sound, Video and game controllers.
If nothing is listed there, is there a listing under "Other Devices" (if mentioned) in Device Manager for an Audio controller?
完成的
same problem here with a Lenovo yoga 710. Intel display audio is listed under sound, video and game controllers. Intel high definition audio under other devices. I've tried scanning for hardware changes and disabling then enabling the devices. hasn't worked. For some reason when I try to scan for new drivers it can't find any. Ive tried manually downloading and installing the audio drivers from Lenovo, and this hasn't worked either. Running out of ideas here...
完成的
Hi @duder1313
Have you tried uninstalling the Intel High Def audio in Other Devices, (and possibly the Intel Display audio as well), restarting the laptop and letting Windows 'find' any new hardware and see what happens?
完成的
there is no audio output my lenovo ideapad 100
完成的
Hi @caynab ,
What OS is installed?
What have you checked? e.g. Device Manager, audio from headphone jack, sound not muted etc
The more info you give the more relevant the answers
完成的
添加一条评论
1个答案
If your laptop’s audio is distorted or does not work, see the Lenovo IdeaPad U530 Touch Has Distorted Audio problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bjbj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,045
