Why do I have Poor picture quality when using antenna
I bought a new viera tv. Pictures from the DVD player was good. However, tv signals via the antenna wasn't good. I observed that the pictures had lines across the screen and it was as if the screen was been scrolled. We tried another tv using the same antenna input and the pictures were fine.
Do you have an external Digital tuner you can connect the antenna to? If that works when connected to the Panasonic, that means you may have problems with the TVs internal tuner.
由 S W 完成的
Hi,
Did you just plug in the antenna to the TV when you first got it and looked at the picture or did you set up the TV by scanning for available TV channels from the TVs Menu Setup area? Try re scanning for TV channels anyway and see if that fixes the problem?
由 jayeff 完成的
